Go to Post Secure your battery well, or it will fly like a fish. - Nate Laverdure [more]
Unread 18-01-2007, 00:45
Plepel Plepel is offline
AKA: Chris
FRC #1877 (Gold Diggers)
Plepel is on a distinguished road
Reflective Spider Feet?
Hello all! This is my first post, so bear with me.
My team was wondering, how reflective are the feet at the end of the spider legs? We had the cool idea that we could mount the camera and an LED to the end of out arm, and then have is search for a reflection of the LED, thus finding where the actual foot it. Would this be possible? The schematics say that they are made out of "bright aluminum", which would be reflective enough, but our members who went to the local kickoff said that the metal was a dull gray. Does anyone know?
Unread 18-01-2007, 03:08
Cpt_Dave_Lister
Posts: n/a
Re: Reflective Spider Feet?
Hmm.. the led might be illegal since it could effect other bots. But you could use the lights that they provide for your robot, the one that is either read or blue... Then again your bot might get messed up with the other bot's lights.
As for the reflectiveness of the spider leg, I am not sure.
Unread 18-01-2007, 06:01
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Usually at local kickoffs (if this is your first local kickoff that you attended) they use the cheaper costing parts to make up a partial segment of the field since FIRST has not built enough fields for each local kickoff event. Not to mention not all events have the space to have a nice looking Field Layout. Which would explain why the metal was dull. The Metal will probably have a clean aluminum color to it for at least a few rounds before being scratched up by the robots. Why don't you try using the camera supplied in the kit and search for the Green Lights. Instead of looking for metal, since a large portion of the field is metal (Barriers, Walls & Goals - They mostly have the same color as well).
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 18-01-2007, 08:16
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Yes, that would work. The choice of frequency is the key.
Unread 18-01-2007, 08:23
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Plepel,
The bottom of the goal will be aluminum diamond plate. It is fairly reflective but will become scratched as robots interact and contact the surface. It is unlikely that your source LED will be considered to interact with other robots unless it is the same color as the goal lights. In any case, teams looking for the goal lighting should be looking up and not down at the floor. You will be subject to inspection on this component at each event. I hope you can make it work, I would like to see it.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 18-01-2007, 10:10
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
What about using a sonar sensor to detect the plate on the rack? Would that be legal?
Brian
Unread 18-01-2007, 10:17
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
i was at kickoff in manchester, i saw the field, and the spider legs are exactly what they say they are, aluminum diamond plate. I would call it "shiny"...but basically if you pick up any piece of alumnium diamond plate and buff it with some kind of cotton you will get what the spider foot looks like.
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 18-01-2007, 12:32
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
We have done some experiments with IR sensors on diamond plate... perhaps a simple reflective sensor may not have the same problems, but with the Sharp IR rangefinders we have found them to have serious challenges when the diamond plate is at anything other than exactly 90 degrees... horizontally and vertically... to the sensor. This is, perhaps, as one might expect, but it was worth trying anyways. Diffuse (non-relfective) objects work great... but the shinyness of the diamond plate is a real pain in our application.
We are going to try some sonar rangefinders, and do have a few applications in mind for the IR, but make sure you test your device on aluminum diamond plate at the earliest opportunity.
Good luck,
Jason
Unread 18-01-2007, 12:47
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
A couple of questions which pop in my head about the do-ablity of your idea:
How far away from the foot do you plan to be? (The farther away you get, the weaker any reflection of your light would be and the more interference you'd get)
Do you hope to detect the foot from an angle, or just perpendicular to it? (The more on-axis you are the better your chances will be)
Don't forget that there is a diamond plate skirt all the way around the bottom of the rack which might create a lot of reflection interference if you're looking at the lower spider feet, but it might also be a bigger target...
Pete Kieselbach
Unread 18-01-2007, 13:21
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Good luck,
Jason
I suggest trying to find some VEX ultrasonics. They are cheap, already in a durable package and prewired (just need a female to female PWM cable, or the standard Y-splitters work too).
Unread 18-01-2007, 14:28
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
The Vex Ultra sonic sensors definitly work, I have only tested it from about 2 feet to about 2 inches but they don't have much trouble with the diamond plate.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 18-01-2007, 14:46
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
Team Role: Leadership
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
one thing to note is the lights at regionals are very bright. they use stage lights to illuminate the field and the reflection from the lights may cause issues when trying to see the reflection of your LED
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
pic: Caution: Stay back 1000 feet Alex Burman Chit-Chat 13 19-10-2006 20:40
1538 Feet High 5yearbarna General Forum 1 22-02-2006 21:03
pic: 36 Feet of CD Mark McLeod Extra Discussion 12 17-04-2005 21:13
Google spider David Kelly CD Forum Support 12 31-03-2005 18:00
Average Feet per Second MisterX General Forum 25 26-01-2004 21:03
