Using a USB to 15 pin converter
I have been looking around online alot for a simple usb to 15-pin converter. That seems like a much cheaper solution then using the usb-chicklet that IFI sells. Is there any reason that wouldn't work, or maybe not legal?
| Voltage-to-resistance converter for using any joysticks | ConKbot of Doom | Control System | 14 | 15-07-2006 12:13 |
| BAFO USB to 9 Pin Adapter | Skiguy523 | Programming | 2 | 29-01-2005 01:49 |
| USB to Serial converter for controller | Ryan Collings | Programming | 10 | 22-01-2005 13:14 |
| USB to 9-pin serial port (HELP!!) | n00b | Technical Discussion | 10 | 01-02-2004 21:25 |
| using set screw or dowel pin/pin to hold on drill motor coupler thinggy | Travis Covington | Motors | 1 | 04-02-2002 03:02 |
