While in the computer lab at midnight last night, thinking about how much weight fasteners will add to our robot, I figured it might be a good resource for some teams if we made a sort of "Weight reduction - How to do it" thread.
So if your in the mood to share, feel free to tell us all how you make your robot lighter. Anything from the smallest task of say, making your spacers have as thin a wall as possible, up to say, removing an arm. |
Re: Weight Reduction
I've said it before:
Replacing steel bolts with aluminum versions. Very light and still strong enough for most purposes.
Even better for some applications. You don't really need a steel or aluminum bolt holding down the RC now do you? Use 2 screws on muffin fans instead of all 4 corners. TRIM THOSE WIRES!!! You don't need 1' of cable going from your battery to your quick connect if the battery is right next to the breaker. ONLY SWISS CHEESE THE BOT IN WEEK 6!!!!!! None of this "speed holes in week 1" nonsense!!!! You can't put material back as easily as you can remove it if you need to mount anything, even something as simple as a potentiometer, limit switch, or a sensor of some kind. |
Rivets, we were able to take almost 5 pounds of bolts off our robot last year by replacing them with rivets. Also choose your materials wisely, sheet metal is your friend, too much extruded aluminum is not. Even if you are not at the cheesing stage yet with your build, plan our where you can reduce weight if you have to, and expect to have to take apart your robot a couple of times throughout the season (keep welding till you know your weight).
Corrugated lexan (green house material) instead of lexan for side shields, and coverings..
Heres a fun story from the Nu-Tron from around 4-5 years ago:
They brought the bot up to inspection and placed it on the scale. The scale read 130.0....130.1....130.0....130.1 (for all you youngens back in the day the limit was 130 pounds WITH a battery). Eventually the scale stopped at 130.1. One of the team members decided to check the air tanks, they were full so he released all the air pressure...the scale dropped to 130.0 and they were good to go. Moral of the story: EMPTY YOUR AIR TANKS! |
This year Team 1323 was able to cut 11 lbs of our basic chassis by welding our frame together it was a task our team was shooting for since the end of last year when we invested in a tig welder.
We've used some fairly large bolts in the past to mount various mechanisms, wheels, etc... A 1/2" bolt is typically overkill in terms of strength, but the diameter has been our requirement. So, we've actually drilled out the center of our larger bolts in order to reduce the weight of this large hardware, and it definitely works.
YMMV, good luck. BEN |
#10
We have a saying that we use over and over when looking for weight reduction;
Steel parts first, then alluminum, then plastic. Cutting/drilling holes in a 1/8" lexan side plate for instance is pretty inaffectual. On the other hand, putting a gear or sprocket in a lath and taking some "meat" off it can pay big dividends. |
#11
Our team is working hard to actually predict weight of the final design in order to avoid the problem we had last year. Every piece is being designed with speedholes included, so hopefully when it all goes together it will be underwieght.
In case anything is heavy and still has room for holes at the end of the build, we have a Rotex punch which can be used to speed up the cheesing process. |
#12
This year it already looks like we are having weight issues so we have been taking the weight of EVERYTHING (components, motors, spikes) and adding them into an excel file. Then for things that arn't built yet like the chassis, wheels and stuff we have done extrememly acurate Solidwork models of them and these give us the weight.
#1 tip to avoid overweight issues: Plan/design everything first then build. dont design as you go. |
#13
weight relieve every sprocket, pulley, gear, and gear box that you can. weight relieve all aluminium and lexan plates. These are some of the densest things on most people`s bots. also, make sure you are using gears belts or chain that is appropriate (not overkill), as jumping up to the next strongest category can mean doubling the weight of these components.
#14
to avoid this?
#15
but do not do this until later in the season like around week 4 or 5 |
| Quoted picture size reduction | sanddrag | CD Forum Support | 1 | 25-07-2006 19:05 |
| Weight Reduction Help. | Mirza95vx | Technical Discussion | 11 | 07-02-2005 16:03 |
| Gear reduction question | dmellich | Motors | 6 | 25-01-2003 08:54 |
| Speed Reduction for Drill Motors | Ian W. | Programming | 5 | 18-01-2003 23:57 |
| Drill Motor Gearbox Reduction Ratios | archiver | 2000 | 3 | 23-06-2002 23:05 |
