Go to Post the jocks may have muscle, but we have extruded aluminum :D - [527]phil [more]
Unread 18-01-2007, 11:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Center of Gravity
I'm preparing a presentation for the team, concering the concept of Center of Gravity, aka Center of Mass. I thought it would be a friendly gesture to share some of it with the CD community, and your feedback will help me too.
I will start by explaining the term "Center of Mass", and also the concept of the Centroid. Then we move to the important part, applying this to robot design. To calculate the CG of our robot, we can find the approximate centroid of the different subassemblies, such as the frame, a ramp, the motor/transmissions, the battery, the manipulator assembly, etc. Each of these can be viewed as acting as a point of mass, and the distance of this centroid from some axis, times the weight of the subassembly, gives a moment that we can sum (keeping track of +/- signs, depending on which side of the axis it is on). We can then divide the sum of the moments by the total weight, to find the distance of the CG from that axis.
There are three different axes that we need to worry about. The first two are the distance of the CG from the side to side center and the front to back center of the robot, and other is the height of the CG from the floor.
The drawings show a generic robot, with a CG located towards one end, a little bit to one side, about a foot and a half above the floor. The diagonal lines show the "tipping angle". When the CG goes past the point of support, either to the front or rear or one side, then the robot will tip over. How far does your robot have to tilt to reach the tipping angle? If it only has to tip a few degrees, then you are probably going to see it laying on it's side in a significant number of matches. If the CG is down low, and centered, then the tipping angle is very far from being vertical, and your robot will stay upright most of the time.
The robot does not actually need to be pushed over by another robot to reach the tipping angle, because of acceleration. The robot's center of mass is also it's center of inertia when accelerating. If you were to apply a driving force as shown by the arrow, the robot will be twisted around the CG, and could easily "do a wheelie" and tip over.
So, it might be worth considering putting most of your weight reduction efforts into the "stuff" that sits up high on your robot, and leave as much weight as you can in the drivetrain/chassis. Also consider the location of small, heavy items such as the battery and air compressor, which could be moved around to balance the robot from side to side or front to back. Think about how the wheelbase and track width affect tipping.
Unread 27-01-2007, 19:03
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: Center of Gravity
Isn't moment of inertia also important in determining whether a robot will tip over?
Even with a low center of mass, if you have large moment of inertia (having a lot of stuff far out from the center of mass...) wouldn't a robot still be prone to tipping?
As far as I know, isn't moment of inertia calculated by the square of the distance from the center of mass, so for example, a really light arm with a heavy grabber device at the end would cause the robot to have large moment of inertia, even if the center of mass is fairly low to the ground with the battery and everything.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
center of gravity and energy macwhoo Rules/Strategy 2 17-01-2007 17:08
Physics: ball launch using gravity JoeXIII'007 Math and Science 8 02-03-2006 18:32
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
Center of Gravity Sachiel7 Inventor 8 02-03-2005 11:00
anti-gravity-gas Adams High Man General Forum 24 28-02-2004 14:43
