Question about lighting conditions in the FIRST competition
Will it be dark during the autonomous mode, or will it be very bright?
I am asking this so I can know if my camera gets the green color even if there is bright light around. |
Re: Question about lighting conditions in the FIRST competition
It will be bright. Very bright.
So how can the camera filter unnecessary light? I'm using the easyC pro default table, will it work with that?
I have done some checking with the camera, and made a function in easyc pro that searches a green light and when it finds it, it stops and writes: Target found. But some problems occurred: if there was some kind of reflection of the green light it stopped. Sometimes it stopped when it saw a florescent light. Sometime it stopped when it saw a bit more sunlight than in another place. So, what do you recommend me to do? |
See my post here:
http://www.chiefdelphi.com/forums/sh...t=41763&page=2 |
You said to do the following: (Qoute):
I also ran into this problem. To fix it (without filters, anyway), write a value of 2 to the saturation control register (register 3), I.E. send a "CR 3 2" to the camera. (end qoute). How do I do that? (I'm programing in easyC pro). |
Indeed, how do you input this in? We tried this through the Java GUI from two years ago, and by changing the parameters through Labview, but it seems to have no noticeable result. The fluourescent lights are bright pink, but so is our target.
Could you provide instructions as to how to input "CR 3 2"? |
| Question: What was the first FIRST competition you attended? | JVN | General Forum | 182 | 25-01-2016 08:24 |
| famous question about FIRST | robot180 | Chit-Chat | 14 | 20-06-2005 10:08 |
| CMUcam II and competition lighting environments | dlavery | Programming | 5 | 16-02-2005 02:07 |
| i have a question about the 2003 FIRST-SME Partnership card | angier314 | General Forum | 7 | 19-01-2003 21:19 |
| Question about Pit/FIRST | Nate Edwards | General Forum | 8 | 12-01-2003 00:41 |
