Go to Post I don't really have a problem with school, as long as it doesn't get in the way of learning. - lukevanoort [more]
Unread 18-01-2007, 18:46
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Controlling a "fork lift" type mechanism.
Obviously it is fairly simple to just move it up and down, however, we have been thinking of ways to control the forklift height mechanism with a slider, or maybe even preset position switches.
I could do the switches, with like limit switches on the robot and move the lift until we hit these, however, I'm wondering how hard it would be to maybe use a dimmer slider type switch, then directly go from the 0-255 given from that, and go to a height based off that value. For example if it's at 127 it goes to the middle spider, 140 is right above that, etc. We're thinking of ways to do it with the gear tooth sensor right now, and it looks somewhat promising, I'm just wondering if you guys know of other (better) ways to do this?
Thanks.
Unread 18-01-2007, 18:51
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: Controlling a "fork lift" type mechanism.
Maybe use reed (magnetic switches) for 3 positions? Just hook them right up to the digital in(s). Just an idea.
Eat, Sleep, Build Robots
Unread 18-01-2007, 19:39
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
How is the lift actuated?
If it is rotary, just put a potentiometer on then.
A potentiometer will give you a precise value per anglular rotation and they don't shift around. Once you have it hooked up you can use software to tell the arm to go up or down until it hits the necessary value.
Unread 18-01-2007, 20:18
Daru Daru is offline
Daru has a spectacular aura aboutDaru has a spectacular aura about
With '05 robot, we tried attaching a pot to our driveshaft for our forklift. We then had a few preset positions, which we could go to with buttons on the joysticks.
The pot kept turning itself, even though it was mounted, and became uncalibrated. I'd recommend you really hunker that thing down.
Also, make it so when you go to a pot value, give it a range of values to stop in, or else you'll get it bobbing up and down.
We ended up taking it off because it was unreliable. If we were given more than a day to get that working, it would have been great
Unread 18-01-2007, 22:53
.999~=1
Hmm, I've been doing some reading and a pot may work well, the only thing that worries me is I don't know how many rotations of our motor it will take to reach peak, as the design/build's team design is not finalized =p;
I think a pot would work though, but I may need a 10 revolution one. I also found something about absolute shaft encoders, which seem perfect. If anyone could recommend me a decent absolute shaft encoder or a decent 10 turn pot it would be appreciated.
Can I "type" code in EasyC? scottmso Programming 1 04-02-2006 07:22
Best type of "pulley" material Nitroxextreme Technical Discussion 6 31-01-2006 22:36
2006 game poll #4 (type of "sensing" in autonomous mode) dhitchco Rumor Mill 1 18-11-2005 12:27
Fork Lift Robot tinyfarnsworth General Forum 64 16-04-2002 12:09
"Ball Return" mechanism... what is it? Randy_Ai Rules/Strategy 1 09-01-2002 16:12
