Go to Post The terror level was lowered to MOE green for this event. - AdamHeard [more]
Unread 18-01-2007, 23:26
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
pic: 1881 tube interface idea
Unread 18-01-2007, 23:30
Ian_Xodus Ian_Xodus is offline
FRC #1896
Ian_Xodus has a spectacular aura aboutIan_Xodus has a spectacular aura about
Re: pic: 1881 tube interface idea
You should use a threaded rod like the one that is provided in the kop, it would be easy.
Unread 19-01-2007, 02:56
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
You could also make the joints of the hand spring loaded and have steel cable retract the fingers in until you line up and then unwind the cable to have the springs pop open the hand.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 19-01-2007, 09:15
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
In addition to the other ideas,
you could simply attach a pneumatic cylinder to the back of finger supports or you could use the same cylinder to pull the wire that edthegeek proposed. pneumatics are usually the way to go for grippers because they don't loosen or back drive when they apply force.
just my thoughts
2004 - 2012: Team 1100
2013 - ????: Team 131
Unread 19-01-2007, 15:01
Rick-906's Avatar
Rick-906 Rick-906 is offline
inventor of the hoverbot-2006
AKA: Richard
FRC #0296 (Loyola Northern Knights)
Team Role: Communications
Rick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to beholdRick-906 is a splendid one to behold
one word: Baller!
The knack of flying is learning how to throw yourself at the ground and miss.
--Hitchhikers Guide to the Galaxy
2006 Archimedes Divisional Champions
2006 Championship Winner
Unread 19-01-2007, 15:08
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
Now that is cool Just make sure that there are no sharp edges
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 19-01-2007, 15:43
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
Once your place the ringer on the post, how do you plan on getting the manipulator back off without hitting anything. Assuming there is allready a ringer on the goal you are going for, would there be any problems getting the manipulator off?
Otherwise, very cool looking design!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 19-01-2007, 18:37
GMAdan's Avatar
We once we release the tube the drive said he know how he is going to do it, so i trust in him.
Unread 19-01-2007, 21:52
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
This was one of my early ideas, but after seeing the round peice of diamond plate at the end of the posts, I quickly discarded it. There is about 1" of clearance between the ring and the plate on the post. And seeing as the "fingers" that touch the ring have to be over 1" or something (I don't know the specific rule) that wouldn't really work.
How you do intend on getting spoilers off of the posts, too? That would be a bit more difficult than necessary.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 19-01-2007, 21:54
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
my team is thinking about using something like that, but with three grabber things
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 19-01-2007, 22:03
GMAdan's Avatar
There is rule of thickness of the tube contactor? I must have over looked it when reading
Well if i do remember the center plate on the post is 10'' the inside of the tube is 13''. This leaves us with 3'' to play with. the fingers are not in excess of an inch in that regard. meaning with fingers in place we have little bit more than an inch left over. Also a side note the image is upside down.
Unread 19-01-2007, 23:27
I forgot to mention the "all the way around" part.
There are ways to make it work, but the only way I can think of is holding the ring above the plate at some angle, then dropping it so the top gets past the plate and lands on the post, while the bottom swings below. That would require a bit extra height when going for the top post.
I think 2 fingers would be better than 3. It would make it easier to get spoilers off of the post.
Also, with the 3 fingers, it might be harder to back away once they release the tube. They were intended to slightly fit around the plate, and once you contract them to release the tube, they wont fit past the plate again.
Unread 22-01-2007, 12:02
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Just a side note, remember this rule when you are scoring
<G33> Field interaction - ROBOTS may push or react against any elements of the field, provided there is no damage or disruption of the field elements. ROBOTS may not grab, grasp, grapple, or attach to any field structure. Robot may not HANG GAME PIECES on the Vision System Targets , or otherwise block visual access to the Vision System Targets. If a ROBOT violates this rule, the head referee will give one warning. If the referee determines that the TEAM is disregarding the warning, their ROBOT will be disabled for the remainder of the match.
When you release a ringer it looks like you are going to need to close your gripper around the end of the spider's foot. But maybe I’m just being unimaginative and don’t see the way your driver plans on scouring.
-Dan Karol
pic: Team #8's Tube Interface dfukuba Extra Discussion 5 13-01-2007 02:04
pic: Height on top of a tube Jeff Rodriguez Extra Discussion 21 13-01-2007 01:46
pic: Team #8's Tube Interface dfukuba Extra Discussion 13 13-01-2007 01:16
pic: 1881 new gearbox design GMAdan Extra Discussion 7 21-12-2006 01:59
I²C Interface on PIC CBM3 Programming 2 01-11-2003 22:28
