Go to Post Big scoop for everyone here: All divisions are stacked with talented teams. It's like this is a really big event or something. - PayneTrain [more]
Unread 19-01-2007, 10:52
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
pneumatics tubning
I have a question. I looked all over the rule book, I just wanted to know if we can use the double coiled pneumatics tubing, like the one from last years kit?
Unread 19-01-2007, 11:00
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: pneumatics tubning
As per the Q&A:
FRC1540
Junior Member
Default Curly Pneumatics Tubing
In previous years teams have made their own curly pnumatics tubing with the standard tubing and a heat gun. While we could do that again (unless R99 disallows it), it seems a lot safer to just allow the real thing. Is that allowed this year? Is making your own allowed?
GDC
Senior Member
Default Re: Curly Pneumatics Tubing
Per Rule <R106> spiral tubing is permitted.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 19-01-2007, 11:58
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by Steve W View Post
As per the Q&A:
FRC1540
Junior Member
GDC
Senior Member
GDC didn't read that rule closely enough when formulating the response. Consequently, while their response is technically correct (some curly tubing is legal), it is potentially misleading.
Originally Posted by <R106>
The following pneumatics items may be added to the ROBOT:
  • Prior year FIRST Kit Of Parts pneumatic cylinders, solenoid valves, and pneumatic tubing may be used in addition to those items in the 2007 Kit Of Parts. Their costs must be accounted for explained in Section 8.3.4.3 Additional Parts - Cost Limits and
    Accounting.
  • Additional 1/8 inch diameter pneumatic tubing functionally equivalent to that provided in the Kit Of Parts, with the pressure rating clearly factory-printed on the exterior of the tubing (note: alternate tubing colors are acceptable).
<R106> allows you to use old KOP curly tubing (e.g. the one from last year), per the first bullet. It does not allow (or disallow) making your own from straight tubes. The rule that covers modifications to pneumatic tubing is <R99>, and it and its equivalents have been interpreted differently from year to year. It is still worth it to ask on the Q&A whether or not permanently bending a tube using heat is a modification, and whether doing the same without heat is legal.
Incidentally, that rule also lets you use the SMC TIUB07 tubing from previous years, as well as the current Freelin-Wade stuff. (And if you can find any, the 1999 kit had some different 2007-legal tubing, if I remember correctly....)
The second bullet refers only to 1/8" (small-diameter) tubing, like the stuff for the venturi vacuum generator. That doesn't mean that you can purchase whatever 1/4" (or 6.35 mm) tubing you want—you're limited to any past or present KOP tubing in that size. Besides, a straight tube is not functionally equivalent to a curled one, so this bullet provides no justification anyway.
Basically, the GDC messed up somewhere, and this is why it's important to state clearly which takes precedence, the Q&A or the rule (last year, we were instructed that it was the rule).
pneumatics edomus General Forum 8 26-02-2003 10:40
pneumatics archiver 2000 3 23-06-2002 22:58
pneumatics archiver 2000 1 23-06-2002 22:42
Pneumatics archiver 2001 1 23-06-2002 22:36
Pneumatics patrickrd Pneumatics 2 05-01-2002 22:11
