Simple question on MPLabs
Well, I'm usually programming in easyC pro, but to be on the safe side, I'm starting to learn MPLabs to. I have downloaded kevin's camera code, but when I compile it fails to compile and tells me it didn't find the stdio.h.
I tried to add the stdio.h file from borlandC (maybe it's a stupid thing, but just to give it a shot), and still, didn't work. What am I doing wrong? ![]() |
Re: Simple question on MPLabs
You just don't have the path set that tells the compiler where to find the system include files.
In MPLAB pull-down: Project -> Build Options... -> Project Set "Include Path" to C:\mcc18\h (you can browse there) and Set "Library Path" to C:\mcc18\lib P.S. You don't want to use any system files, such as stdio.h, from any other compiler than what came with mcc18. They are Microchip PIC and C18 specific. Last edited by Mark McLeod : 19-01-2007 at 12:48. |
Ok, thanks. Now it worked. And I've noticed it had problems if the the file path length is larger than 62 chars.
Project -> Build Options... -> Project Go to the "MPLINK Linker" tab Click on "Suppress COD-file generation" Creating that file is when you get the 62 character limit message, and it isn't used by us for anything so it's unnecessary anyway. |
MPLab works with collections of files called "projects". You can open and edit arbitrary text files with it, but you can only compile a project. Projects are defined in .mcp files, and you open them by choose "open project" from the "project" menu.
We did that, and included the c files in the project and still go no soure files??? Not sure what to do, am I right that you create new project,
add files from existing files from kevins code so that you can compile and rebuild? That is what we did but when we try to build the project we are getting the no source files even though they are in the directory |
You should be starting with a predefined project, either the default code from IFI or the camera-enabled code from Kevin's site. Unless you're already very experienced with MPLab, there's no reason for you to create a project yourself.
If you start with the default code and want to add encoder or gyro support, for example, you should follow the very clear directions included with each module Kevin provides. Last edited by Alan Anderson : 20-01-2007 at 00:11. |
| Quick Simple Question | ImmortalAres | Programming | 8 | 17-06-2005 13:08 |
| simple joystick question | vexingspector | Programming | 5 | 19-02-2005 18:55 |
| MPLABS Question | Bharat Nain | Programming | 13 | 16-05-2004 16:19 |
| simple question... answer it | archiver | 2001 | 1 | 24-06-2002 01:02 |
| simple engineering question | Ben Mitchell | Technical Discussion | 2 | 07-11-2001 07:50 |
