Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 19-01-2007, 18:09
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Programming Pneumatics?
How does one program pneumatics?
Thanks.
Unread 19-01-2007, 18:21
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: Programming Pneumatics?
Check the following threads for some basic information:
http://www.chiefdelphi.com/forums/sh...ad.php?t=44079
http://www.chiefdelphi.com/forums/sh...ad.php?t=34872
Pneumatics are fairly simple to program and are run off of spikes. There have been quite a few posts similar to this one so in the future please search before you post, especially with such a general question.
Unread 20-01-2007, 00:30
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Basically, the two main components, compressor and valves, are run off of spikes. The compressor only really needs to go in one direction, pumping into the tanks. The valves need two, one for pushing, one for pulling. Use spikes for both, and note that you only need to send a single pulse at a time to the valves, but you treat the compressor like a motor. Check out the IFI Robotics page on Spikes and the Programming manual to figure the programming.
Code:
void function(void)
  function();
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
Programming of Pneumatics Ben Piecuch Programming 3 18-02-2005 02:39
Pneumatics Programming KWalsh Programming 8 19-02-2004 09:17
Programming PBASIC for pneumatics archiver 2001 2 23-06-2002 23:58
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
