Go to Post I would have bought a bigger box of popcorn and sat up higher in the stands. In the middle. - JaneYoung [more]
Unread 19-01-2007, 21:16
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
cncsprockets
We've recently acquired a small cnc machine and i've created some sprockets using inventor design accelerator and made them and the chain doesn't fit
so basically what i'm asking is can someone create and email me the inventor files for a 32 tooth sprocket and a 64 tooth sprocket both for #25 chain.
i made 5 sprockets before found a way to trick it into spacing that fit. i ended up making a 31 tooth sprocket with design accelerator then modifying the pattern for 33 teeth then it worked enough but the chain doesn't quite sit down.
so i'm asking for 2 accurate inventor files for these 2 sprockets or what i'm doing wrong.
thanks
aren
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 20-01-2007, 16:44
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: cncsprockets
Try a search for previous thread that have discussed this. Here are two, but there may be more.
http://www.chiefdelphi.com/forums/sh...ad.php?t=51432
http://www.chiefdelphi.com/forums/sh...ad.php?t=41765
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 20-01-2007, 20:43
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
Re: cncsprockets
thanks
aren
I have also noticed that the Inventor geometry for #25 chain is incorrect. I am not entirely sure what it is, but we I attempted to CNC a sprocket using the Inventor model, the chain did not fit as well (so you are not doing anything wrong). As far as what to do, I can only suggest that you consider making your own profile for the teeth and work from there. Take some calipers to the chain and the incorrect sprocket and see where Inventor went wrong and try to fix it manually. If you are short on time however, it may be more cost-effective to buy them.
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
