Go to Post One of the Minbot inspectors at LA asked me how much a switch had to weight before it stopped being a "light" switch and started being a "heavy" switch. - ChrisH [more]
Unread 19-01-2007, 21:46
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
What guage wire do you use for 40A circuits
Trying to decide what guage wire to use for 40A motor circuits. Even though <R87> allows 12 AWG wire to be used, I'm thinking of using 10 AWG. I like to make things better than the minium. Am I just wasting money on bigger wire, or do you think its worth it? I also believe it will crimp getter. What do you use?
Brian
Team 1225 Team Mentor
Unread 19-01-2007, 22:02
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: What guage wire do you use for 40A circuits
Brian
From the breaker switch to the distribution block, and from the distribution block to the maxi block, we use the required 6 AWG wire. From that maxi to the victors, we use 12 AWG. In both cases, the gauge of the wire is overkill for safety reasons. However, if you would rather use the heavier gauge wire because it's easier for you, then use that.
Unread 19-01-2007, 22:32
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Wire with larger cross section has less electrical resistance per unit of length, and therefore drops less voltage and dissipates less power than wire with smaller cross section. In Europe and most other parts of the world, wire cross section is expressed in square millimeters. In the US it is more often expressed in AWG (American Wire Gage) units, a logarithmic scale defined by this formula:
AWG = 10 + (10 * log10(R)), where R is resistance per unit length, measured in Ohms per thousand feet of wire.
So 1000 feet of 10 AWG wire is equivalent to a one Ohm resistance. Scaling to dimensions more appropriate to FRC, ten feet of 10 AWG wire is equivalent to a 0.01 Ohm resistance. A current of 40 Amperes flowing in that wire will create a 0.4 Volt drop, and dissipate 16 Watts. The same 40 Amperes flowing in ten feet of 12 AWG wire will create a 0.63 Volt drop, and dissipate 25 Watts.
So using 10 AWG instead of 12 AWG keeps your wiring cooler and makes more power available to your motors; the trade off is higher cost and weight of the thicker wire.
My team uses 10 AWG for our 40 Ampere circuits.
Richard Wallace
since 2003
Unread 20-01-2007, 14:13
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Expanding on Richard's post above, I like to the use the analogy of the "Wire Foot". This is an easy way to calculate out losses on the robot. The Chalupa and FP motors have stall currents near 100 amps. #10 wire has about .001 ohm per foot, which at 100 amps drops .1 volts. Add up the length of wire (both sides, black and red, please) and you can easily see how much drop you will encounter for your design. A few fudge numbers for you as well...one foot of #6=.5 wire feet, #12=2WF, Victor=2WF, battery internal resistance=11WF. Good connections should have very little resistance but bad crimps and loose hardware can account for as much as 1 or 2 WF per connection. Add in 1WF for breakers (total) just to be on the safe side. Once you have made the simple calculation then compare it to the motor graph for your motor. If you cannot supply a full 12 volts then the preformance of your motor slides down the graph to a lower performance area of the graph. If you had designed for peak torque, addig 6 ft. of #12 will not allow you to achieve your design goals.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 20-01-2007, 18:06
Rookie Year: 1996
Originally Posted by Al Skierkiewicz View Post
Expanding on Richard's post above, I like to the use the analogy of the "Wire Foot". This is an easy way to calculate out losses on the robot. ...
Thanks for posting about your Wire Foot method of analyzing electrical system losses, Al. I think you have mentioned it a few times previously on these boards.
Maybe you have already posted this elsewhere, but if not it would be very helpful if you provide a list of WF values associated with typical FRC electrical system components, and some more examples of how your method can be used by FRC teams planning their electrical layouts. Is this already a CD White Paper?
Richard Wallace
since 2003
Unread 21-01-2007, 14:29
Unsung FIRST Hero
Rookie Year: 1996
I have only made this part of my presentations at Championship. If you think it would be helpful, I will assemble a simple table and an example or two. I need to add something for this year's presentation anyway. Thanks!
Al
WB9UVJ
www.wildstang.org
Unread 21-01-2007, 14:58
Rookie Year: 1996
Thanks again, Al. I'm sure that many of us will look forward to seeing your table and examples when you have them ready. If I get to go the Championship this year it will be fun to attend your presentation.
Richard Wallace
since 2003
What program do you use for webdesign? Rez648 Website Design/Showcase 42 24-05-2004 17:19
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
What do you use scouting for? Jack Scouting 33 28-04-2003 10:12
What do you YOU use your bins for? AlbertW General Forum 40 13-04-2003 04:18
Bosch Motor Wire Guage gail OCCRA 6 22-10-2002 00:47
