Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 19-01-2007, 21:53
NinJA999's Avatar
NinJA999 NinJA999 is offline
Chipmunk NinJA
AKA: Nick Aldwin
FRC #0811 (Team 811)
NinJA999 will become famous soon enough
Send a message via AIM to NinJA999
Post Joystick Linearity
Here are the results of our test of two calibrated default joysticks. We used a ruler to see the changes in mm every 20 y values (using dashboard to see the values). We have concluded that they are linear.
Another Link To The Graph
Team 811 (Nashua, NH) - Mentor
Previously Team Lead & Programming Lead
Unread 27-01-2007, 22:29
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Joystick Linearity
They better be! They use linear potentiometers, after all.
That said, the linearity of the joystick can be misleading. If you do open-loop drive control (i.e. pwm01 = p1_y), you will find that the speed of the motor on pwm01 will NOT increase linearly over the entire range of the joystick.
Unread 28-01-2007, 10:21
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Right. We have implemented code that makes the pwms linear, and it runs so much more smoothly now.
Unread 28-01-2007, 15:41
gburlison gburlison is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rookie Year: 2000
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
We implemented a look up table to purposely make them nonlinear. We like more sensitivity around the center to make it easier to drive slow and precise. We lose sensitivity at full speed, but when you want to go fast sensitivity is not as important to us.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 28-01-2007, 18:49
NinJA999's Avatar
Chipmunk NinJA
AKA: Nick Aldwin
Interesting. To do that we implemented a reduced speed switch on the trigger.
1 joystick or 2? ChrisMcK2186 Control System 18 19-01-2007 23:42
joystick ? _GP_ General Forum 1 26-02-2004 23:10
Joystick rmmlg Inventor 0 15-02-2004 16:34
No Joystick archiver 2001 2 24-06-2002 01:14
Joystick Absolute Value Technical Discussion 21 22-02-2002 10:56
