pic: 612 New Drive System
Re: pic: 612 New Drive System
WOW
Did you include every bolt in that assembly!? |
Nice. You may want to consider a bearing to support the outboard end of the gearbox shafts. There has been discussion of this in other threads, and the advice generally seems to be that if you are not using an outboard support bearing, then make sure you mount the sprocket as close to the gearbox as possible to minimize the cantilevered load on the gearbox shaft. (You can also cut off the unused shaft to save weight, in that case.)
We used a six wheel drive setup last year and loved it... we added omni wheels to one end of the robot, however and found that helped our turning significantly. Not all teams need to do this, but we had very grippy wheels on all corners... even with the centre wheels lowered slightly we still had a problem turning. Jason |
The best part of the drive-train is the wheels, but I'll let them post the pictures. ![]() |
Jason,
thanks for your input! I was wondering what kind of grip you had on your wheels the year you had the turning problem? |
| pic: New Drive System for 703 | POLISH703 | Extra Discussion | 53 | 19-01-2007 17:33 |
| pic: rookie drive system | psycho7 | Robot Showcase | 13 | 13-03-2006 10:29 |
| pic: Team 612 Drive System | RoboMadi | Robot Showcase | 7 | 08-02-2006 16:38 |
| pic: SimSwerve Omnidirectional Drive System | CD47-Bot | Robot Showcase | 6 | 12-06-2004 14:09 |
| pic: Drive System | CD47-Bot | Robot Showcase | 3 | 27-02-2003 14:11 |
