| View Poll Results: What are using to help you program the camera? | |||
| LABView |
4 | 25.00% |
| EasyC |
12 | 75.00% |
| MPLab |
4 | 25.00% |
| Kevin's Code |
4 | 25.00% |
| ChiefDelphi (haha) |
4 | 25.00% |
| Multiple Choice Poll. Voters: 16. You may not vote on this poll | |||
How do you import code from labview to easyc?
The only output from labview to easyc for the camera configuration that we could find was an .ini file, but easyc wants us to import an .ecc file to Initialize the camera. Anyone have any suggestions? Also, how many people are using Labview & EasyC to program the camera (instead of Kevins code... MPLab...)? |
Re: CMU cam EasyC config
We had the same problem, however you can write down the values from Labview and put them in manually in EasyC. Really, though, the easyC default settings seem to work just fine for us.
We opened the file with notepad, and resaved it under the type all files with a .ECC ending. It seemed to work just fine.
We are getting ready to fix this in a update to easyC that uses .ini. If you change the extension to .ecc it will work file. Also the default values in easyC are calibrated very well for this years color.
| CMU cam | Booger | Programming | 3 | 18-07-2006 00:00 |
| CMU Cam on an EDU-RC | Redneck | Programming | 2 | 11-02-2006 14:55 |
| CMU-Cam power | QuantumNinja | Programming | 1 | 01-02-2006 21:14 |
| CMU CAM setup | stephenthe1 | Programming | 0 | 17-01-2006 11:36 |
| CMU Cam GUI | Arc736UV | Programming | 2 | 15-03-2005 19:26 |
