Go to Post For Pete's sake, don't concentrate on the entry itself... concentrate on what your team is doing to make an impact in your community. - Andy Baker [more]
Unread 20-01-2007, 19:51
maniac_2040's Avatar
maniac_2040 maniac_2040 is offline
AKA: Matt
FRC #3302 (Turbo Trojans)
maniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these partsmaniac_2040 is infamous around these parts
Send a message via MSN to maniac_2040
12 Volt Battery Substitute
Hey, I'm the programmer on my team and I'm using a Vex bot to test code on while the main robot is not complete, but I'm using the regular Robot Controller, which takes a 12 volt battery. As of right now, I am just using a 12 volt power supply, which is very inconvenient because the robot has a cord dragging behind it when I try to drive it and a regular 12 volt battery is much too big/heavy to put on this miniature bot. So my question is are there smaller and lighter 12 volt batteries I can use? Or, is it possible to use a 7.2-9 volt backup battery as the main power source? seeing as how I only have a few vex motors(which are powered via the backup battery anyways), a gyro, and possibly a CMUCam (also powered via backup battery) on the bot.
Thanks in advance.
MK 12 volt battery question Seki Electrical 54 03-03-2007 02:09
7.2 Volt Battery Justin_302 Electrical 4 28-01-2005 23:25
Gasoline substitute? Bcahn836 Chit-Chat 13 30-05-2004 18:55
6 Volt charger...? kangarue23 Technical Discussion 7 12-04-2002 10:35
Substitute Parts BHSFirst Off-Season Events 1 08-11-2001 19:23
