Go to Post Are you asking if I can pick up electrons? I'm positive. - Gary Dillard [more]
Unread 20-01-2007, 23:51
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Problem with MPLAB
I'm using Kevin's camera code and running MPLAB v7.50. When I try to compile the code I got an error saying
Couldn't locate build tool. Check tool locations.
I've tried reinstalling MPLAB but that hasn't fixed the problem. Any ideas?
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
Unread 20-01-2007, 23:53
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Problem with MPLAB
You received V7.50 in the kit of parts?
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 20-01-2007, 23:58
dpick1055's Avatar
David Pick
No this is on my home computer. I downloaded this copy from the microchip website so I could work on code at home.
Unread 21-01-2007, 00:20
dpick1055's Avatar
David Pick
I did some more digging and found that I'm missing the C18 C complier (pretty important). Anyone know why that might not have been installed or where I can get it?
Unread 21-01-2007, 00:23
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
the c18 C compiler should be on the MPLab CD you got in the kit of parts. you install it separately.
Unread 21-01-2007, 00:34
dpick1055's Avatar
David Pick
Ahh ok thanks.
Please help; HUGE mplab problem brennerator Programming 5 09-01-2007 01:25
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
MPLAB IDE Problem amateurrobotguy Programming 10 26-02-2005 09:29
Problem with MPLAB d.courtney Programming 5 02-02-2005 21:42
