Go to Post Ban the ingredients for cheesecake, and stores will find substitutes. Remove the market for them, and stores have no reason to make them. - Rachel Lim [more]
Unread 21-01-2007, 13:46
dawilliams dawilliams is offline
FRC #2028
dawilliams is infamous around these partsdawilliams is infamous around these partsdawilliams is infamous around these parts
Compressor included in weight?
R11 says only battery and bumpers aren't included in weight, but R101 says
Note: the intent of this rule is to permit teams to take
advantage of the weight savings associated with keeping the compressor off-board. But
using the compressor off-board of the ROBOT does NOT permit non-compliance with any
other applicable rules.
does this mean compressor weight IS or IS NOT included in weight of robot?
BTW - We're rookies and like other teams we're having trouble posting on the FIRST Forum.
Unread 21-01-2007, 13:51
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: Compressor included in weight?
You can make use of pneumatics with or without the compressor on your robot, although if you do not use it, you must have wiring as though it is on the robot. If you put the compressor on your robot yes, it's part of the weight total. If you don't put the compressor on your robot it doesn't count towards your weight.
As for the Q&A part, are you attempting posting in the "Ask a question" subforum? It took me a few minutes to figure that out.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 21-01-2007, 13:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
The Q&A can give you a definite answer, if you can get thru, but it sounds to me like they mean:
You can decide to have the compressor onboard or offboard. The onboard compressor weight is not like the battery or ramps, it DOES count as part of the weight of the robot. Leaving it offboard saves weight, as the compressor won't be part of the robot's weight.
The note means that your offboard compressor plumbing and wiring systems need to comply with the robot rules, as far as how it is connected, having pressure regulation and safety valves, and other safety considerations.
Unread 24-01-2007, 14:15
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Squirrel,
Just so as not to confuse anyone, the battery is not included in the weight but all attachments are included. Bumpers are weighed differently after the robot is weighed but ramps must be included in the weight.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-01-2007, 13:51
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
You need to decide whether or not you NEED a compressor on board. If some type of pneumatic device is powering a crucial part of your robot, like something that will actuated a bunch of times, then a compressor would be required incase your air supply runs out. But if you only need no more than 4 full tanks of air on your bot, then leave it off for the weight.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Pirates vs Ninjas (poll now included!) Master Spoon Chit-Chat 49 12-07-2006 20:47
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Battery not Included Wetzel Rules/Strategy 10 08-01-2005 22:35
[FVG]: Included Bots Mike Ciance FIRST-related Organizations 37 27-08-2004 19:16
social life not included Andrew Dahl Chit-Chat 10 14-01-2002 03:30
