Go to Post The greatest lesson we can teach our kids is how to win. - AdamHeard [more]
Unread 22-01-2007, 14:29
Bob22341 Bob22341 is offline
FRC #1870
Bob22341 will become famous soon enough
Speed Sensors
I am planing on implementing a speed sensor on my team's robot, and I am wondering what sensors other teams use to tell how fast their robots are moving.
Thanks
Unread 22-01-2007, 14:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Speed Sensors
Accelerometers and encoders are excellent choices.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-01-2007, 14:59
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Re: Speed Sensors
Probably you want an encoder. Accelerometers can be used, but tend to have more error than encoders (both because use must integrate acceleration from it to get velocity, and because accelerometers tend to get a decent amount of noise in their output).
Many teams use the Greyhill encoders that can be obtained from Digikey. Another available for encoders this year is to buy the encoders designed to hook right up to the Banebots kit transmissions (available at the Banebots website).
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 22-01-2007, 19:59
Nick E Nick E is offline
Robotics, eh?
FRC #0888 (888)
Team Role: Mechanical
Nick E is an unknown quantity at this point
Send a message via AIM to Nick E
Re: Speed Sensors
Well, you could probably do it simply, if you had an optical sensor, that looked down at the wheel...have some kind of mark on the wheel, make the sensor count how many times it "see's" it in a second..then plug that in to some kind of program(becasue you can figure out how far the wheel travels with each rotation) and do it like that. Im not sure how hard this would be from a programming standpoint, but I don't imagine it would be too hard.
That was one heck of a run-on sentence...whew!
Unread 25-01-2007, 13:18
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Speed Sensors
There are really two options i am aware of: Accelerometers and gear-tooth/encoder/banner sensors.
The main advantage of an accelerometer is that it will mease the robot's net acceleration, not the wheel revolutions. Basically, it measures your actual acceleration (can be converted to velocity relatively easily). This means that in a situation (such as running into a wall/other robot) where your wheels are spinning out, you will get an accurate speed reading, whereas with an encoder-style sensor you will not!
However, encoders are certainly simpler to implement, so look at the application and decide what sort of accuracy and reliability you need, and then choose which sensor to use.
//Dillon Compton
Team 1394
www.metalmoose.com
Unread 25-01-2007, 16:36
DARKAGE's Avatar
DARKAGE DARKAGE is offline
AKA: Vic
FRC #0441 (Devil Dogs)
DARKAGE is an unknown quantity at this point
Send a message via Yahoo to DARKAGE
Re: Speed Sensors
how do you connect the speed sensor???
Unread 25-01-2007, 16:53
lukevanoort lukevanoort is offline
in between teams
AKA: Luke Van Oort
lukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond reputelukevanoort has a reputation beyond repute
Send a message via AIM to lukevanoort
Re: Speed Sensors
If you use encoders of some sort and have the weight/space I'd suggest mounting them on a non driven wheel that touches the floor to eliminate error from the robot doing spinning its wheels.
Team 1219: 2009 - Mentor
Team 587: 2005 - Animator, 2006-2008 - Team Captain
Unread 31-01-2007, 13:54
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Speed Sensors
Accelerometer doesn't tell you current speed, it just measures acceleration. And if you are turning at the time, you will get the forward component of acceleration plus the lateral component (2-axis accelerometer).
Using encoders, you can figure distance travelled, speed, and acceleration.
Put an IF statement in your code that executes its inner code at a known rate (eg: 10 times per second).
Code:
if (time_elapsed_100msec)
   Speed = CurrentEncoderCount - prev_EncoderCount;
   Acceleration = Speed - prev_Speed;
   prev_EncoderCount = CurrentEncoderCount;
   prev_Speed = Speed;
Wheel Speed Sensors / Vehicle Speed Sensors chitu Technical Discussion 11 12-01-2008 02:46
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
sensors edomus General Forum 5 19-11-2003 16:46
Speed Sensors archiver 2000 7 23-06-2002 23:01
