Go to Post "The world is not idiot-proof. Pay Attention." - DonRotolo [more]
Unread 22-01-2007, 17:19
Terry Yiu Terry Yiu is offline
FRC #0849 (Wolf Pack)
Rookie Year: 2007
Terry Yiu is an unknown quantity at this point
Servo tracking... pan reverse
Hi, I have a question about the servo tracking for the camera. The tilt tracking works fine... follows the green light. However, the pan servo moves AWAY from the green light. It seems that our pan tracking is reversed and we do not know how to invert it back on EasyC.
Any help would be appreciated. Thanks.
Unread 23-01-2007, 22:18
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Re: Servo tracking... pan reverse
Invert it like this (pseudocode)
pan_pwm = 255 - pan_pwm;
Unread 23-01-2007, 22:26
Cynix Cynix is offline
FRC #0074
Cynix is an unknown quantity at this point
If you're using Kevin Watson's tracking code look in tracking.h and find
Code:
#define PAN_ROTATION_SIGN_DEFAULT
That will be set to either 1 or -1, if your pan is tracking the wrong way try switching the value. I've never used easyc but you can open tracking.h in any plaintext editor like notepad and change the value manually.
Quetion about servo tracking function in easyC pro itsme Programming 5 31-01-2007 11:30
Servo & Tracking Problems Team 849 Programming 4 28-01-2007 01:28
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
Tracking beacon without servo Paul Marshall Technical Discussion 17 10-02-2004 20:58
