Go to Post Oh, for the love of cod, can't you see that Dave is messing with us just for the halibut? When the actual clue comes out, I'm sure we'll all be singing a different tuna. - Pat Fairbank [more]
Unread 23-01-2007, 08:23
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Modifying 40 Amp maxi fuse block
Steven,
It was legal in the past to remove the unused portions of the Maxi Fuse block to save weight. This question has not been asked or answered this year to my knowledge. Keep checking the Q&A or make sure you post this question. In any case, the block must be protected with the clear plastic cover that shiped with the block for insulation purposes.
As many have pointed out, it is within the rules to use smaller breakers and smaller guage wire if a team chooses. The breakers are sized to appropriately protect the wire guage as specified. (for those of you who will look this up and find discrepancies, remember you can derate the safety margins since the wiring is in the open air and you only have a few minutes of "ON" time) So you can make the changes but WHY??? By moving to #12 wire from #10 and downsizing the breaker you provide a 50% increase in series resistance and further limit the power of the motor. By moving down to a 20 amp breaker and #14, you may have a hard time starting a motor under load. The FP and CIM motors are capable of 100 amp stall currents, all you will be doing is tripping the breakers which make them hot and cause them to trip more often. I can hear some of you saying 'but I am designing the system to not stall the motors'. The definition of a stalled motor is one which is not turning, therefore every motor is in stall when it starts.
The buzzing you here is the breakers rapidly tripping and resetting.
Al
WB9UVJ
www.wildstang.org
________________________
Warning! Check the screws on your Maxi fuse block! Roland Electrical 1 16-03-2004 21:59
Do we need to use the gnd stud and MAXI fuse block Noah Melamed Electrical 14 03-03-2004 20:38
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
pic: 40-Amp Fuse Block CD47-Bot Robot Showcase 7 20-02-2004 00:23
Maxi 40 Amp Fuse Panel mtrawls Electrical 25 13-02-2004 15:19
