Go to Post No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. - Tytus Gerrish [more]
Unread 23-01-2007, 16:55
nyu500 nyu500 is offline
FRC #2207
nyu500 is on a distinguished road
Rookie Team's Needing Help!!!
We finished our wheel base and things like that, but I was curious to know if anyone knew how to make sticky wheels (I'm not exactly sure but I know they are homemade with various chemicals). We were also wondering if anyone knew of a site that sells fabric cheaply and what type of fabric we should use to cover our borders. Same with floaties, we can't seem to find any inexpensive ones.
Unread 23-01-2007, 17:07
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: Rookie Team's Needing Help!!!
As for wheels the best thing to do if you are using the kit ones is to lathe or sand the wheels down flat and then screw on roughtop conveyor tread from mcmaster. You can also glue the tread on if it helps. Just be careful you don't have too much traction particularly if you are 4 wheel drive because it will be really hard to turn.
Mentor 2415
Unread 23-01-2007, 17:11
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
First welcome to CD and to FIRST.
Here are some online sites to buy pool noodles or you could go to your local pool store or WalMart or Kmart to buy some
http://www.poolcenter.com/pooltoys_n...water_logs.htm
http://www.9thtee.com/pooltoys.htm
http://pooltoy.com/waternoodle.html
The fabric can be bought at any arts and craft store and you can even find your teams colors or buy white fabric and dye it your teams colors.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 23-01-2007, 17:14
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
1) "Sticky" wheels. Check manual section 8 rule 34... "Gaining traction by using adhesives or Velcro-like fastener material is not
allowed." Presumably you are just looking for a way to have a soft, high-friction tread for your robot, not something actively sticky. The wheels in the kit are good in this regard, however you may wish to check with IFIRobotics.com and andymark.biz for some tread ideas that other FIRST teams have had success with. Be careful that you test your robot on carpet, not just a shop floor. If you have TOO MUCH traction, you may not be able to turn efficiently.
2) Fabric: by "borders", I presume you mean "bumpers". Check a few rules down in Rule 37 and you find that 1000 Denier Cordura Plus is the recommended fabric. Other sturdy rip-stop nylon fabrics may be used, but the heavy duty cordura is recommended for a reason. I am sure if you ask around your community someone will be able to point you towards a fabric store that can help you, but if not, try googling "cordura"... you might find a list like this: http://lycraprl.invista.com/public_r...BrandAll =All
3) Pool noodles can be found on-line (try searching Chief Delphi, I believe some sources were mentioned last year) or trying "google". As for cheap ones, ask at nearby aquatic centres. I found some for $1.99 at Canadian Tire last year... but that probably doesn't help you a lot, eh?
Good luck,
Jason
poor little newbish programmer needing help Oumonkey Programming 13 14-07-2005 21:47
Rookie help doyler Technical Discussion 55 11-01-2005 08:59
Needing A header file jweric Programming 19 23-01-2004 10:25
Needing a Sponsor.... again! archiver 2000 0 24-06-2002 00:18
Need help with strategy? Here's my team's method! Khalicl13 Rules/Strategy 4 10-01-2002 17:40
