Go to Post FIRST robots are not six week projects. They are never ending projects where the requirements are changed on an annual basis. - ChrisH [more]
Unread 23-01-2007, 16:56
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Camera will track one light, but not two?
If the title applies to you, try setting the confidence threshold in the tracking menu or tracking.h to a lower value. Please let me know if anyone has seen this problem.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 29-01-2007, 23:46
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Camera will track one light, but not two?
Team 11 lowered the confidence and it worked great with two targets...
Unread 01-02-2007, 22:34
abrockhoff abrockhoff is offline
AKA: Alex Brockhoff
FRC #0011 (MORT)
abrockhoff will become famous soon enough
Send a message via AIM to abrockhoff
Yes, I think we went as low as 5 for the confidence value (using our own values for Track Color) and we were able to track the two without any problems.
Camera track and drive integration code Inverted Programming 2 25-01-2007 02:00
Camera finds overhead lights not green light theycallhimtom Programming 4 20-01-2007 17:37
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
Camera did not work for well at the regionals, but worked great at home. Alan Ing Programming 12 17-04-2006 17:43
LabVIEW - CMUcam finds target but cant track bear24rw Programming 6 13-01-2006 21:43
