Go to Post Scientists ask Why, Engineers ask Why not. - Rohith Surampudi [more]
Unread 23-01-2007, 19:43
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Image Problems
We are currently testing our camera and where the lens of the camera is pointing is not where the picture is. For example when we are directly between the two lights and the camera sees the two lights the lens of the camera is pointing more to the left of the target than in the center. Can anybody help me with this problem PLEASE
Unread 25-01-2007, 01:53
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Re: Image Problems
I have the same problem, but i think it because the servos are set 124, 124 versus 127 could make that little difference. If u are using the steamlined version. you can go to tracking.h and set the PAN_CENTER_PWM_DEFAULT to 127. let me noe if that helps
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 02-02-2007, 21:32
Dman Dman is offline
Dman
AKA: Derek Manwaring
FRC #1566 (Ammoknights)
Dman is an unknown quantity at this point
Re: Image Problems
Yeah, we have exactly the same problem. I don't think it has anything to do with the servos because the camera lens is the thing that is pointed more toward the left while the image appears to be centered. Help would be much appreciated!
Unread 02-02-2007, 21:40
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Image Problems
You need to offset the center of the target in tracking.h
// These two values define the image pixel that we're
// going to try to keep the tracked object on. By default
// the center of the image is used.
#define PAN_TARGET_PIXEL_DEFAULT 79
#define TILT_TARGET_PIXEL_DEFAULT 119
Try changing the pan up and down to find the number that best centers your camera
Unread 03-02-2007, 12:06
Dman
Re: Image Problems
I had thought of that, but why isn't the image centered with the lens anyway? Maybe we'll just make our own camera without that mistake... he he
Unread 03-02-2007, 23:44
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: Image Problems
Yeah, I'm not sure if it is a mechanical problem or if it is a firmware problem with the camera.. we found we had to offset it quite a bit to get it to look straight. We noticed this problem all three years..
Anyone know why this occurs?
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Problems muy dificil Programming 5 26-10-2005 17:10
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Image Discuss: FESTO Problems CD47-Bot Extra Discussion 3 16-02-2003 10:57
Problems- archiver 1999 0 23-06-2002 23:00
