Go to Post Programming team motto: If it doesn't work, use a bigger hammer. - WizenedEE [more]
Unread 23-01-2007, 22:32
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
how do we update our robotcontroller code to u013 from u012?
Unread 23-01-2007, 23:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: how do we update our robotcontroller code to u013 from u012?
The master code is in the FRC_MASTER_V13.BIN file that comes along with the default code. Use the IFILoader program to send it to your RC just as if it were a .hex file.
You'll have to reload the user code .hex file after you've updated the master code.
Unread 24-01-2007, 04:21
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
thanks! its like almost midnight in Hawaii, so all of you must be getting ready to wake up!.....hehe....
anyways, we honestly think its the problem after troubleshooting our robot radio cutoff issues.
With a 2005 and 2006 RC and OI both interchanged with the respective radios, our NEW robot works fine. However, once you change to the new radios, its keeps shutting off intermittently.
This is running off the u012. I will post our test results tomorrow night after we upgrade to 013!
Aloha!!!!
Unread 24-01-2007, 04:23
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
id like to hear from teams who have last years robot and switch to new radios and see what happens? If you do, do you have the same results as us?
Master code update Eldarion Control System 1 09-03-2006 21:14
how to convert Easy C code into real code? TheHolyLancer Programming 1 29-01-2006 09:09
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
One last question about our code dddriveman Programming 5 22-03-2004 09:49
update on our robot Stormhammer Robot Showcase 9 22-01-2004 09:48
