Go to Post If it's good enough for Star Trek, it's good enough for FRC. :) - KarenH [more]
Unread 23-01-2007, 23:35
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Wiring the Compressor
Twice now, over the course of the past week, we've managed to blow the 20 amp spike fuse with the compressor. We've triple-chcked our wiring, according to this year's power distribution diagram. The Spike's power does go through a 20 amp breaker before it gets to the spike, and the spike is hooked up to a relay. The RC is programmed to run the compressor automatically when the pressure switch, which is wired to a digital input, is released, and turn it off when the switch is triggered.
My first guess is that the spike is bad, especially considering how the plug for the "PWM cable" on the spike itself seemed to be faulty; if I jiggled it a bit, the signal tended to be cut (as in the LED turned off completely, which is only supposed to happen when the fuse blows). We switched out for a different spike, but haven't really had enough time to see if the problem is fixed. We think it has been, after measuring the current and running it a bit, but I figured to be sure, I'd ask if anyone else can see something we're not or has had a problem similar.
Code:
void function(void)
  function();
Unread 23-01-2007, 23:41
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: Wiring the Compressor
maybe your digital input is in backwards?
seeing as you switched the spike, it was probably a bad spike. please do inform us if the problem comes up again.
(perhaps that code in your signature is the problem (= )
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 24-01-2007, 00:03
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
From the 2007 FRC Pneumatics Manual See page 3
http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
A spike relay must be used to control the power to the compressor using a 20amp breaker, not a fuse.
We have done this in the past, replacing the fuse with a 20amp snap action breaker in the spike module.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 24-01-2007, 01:00
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Jake,
Mike (Phalanx) is correct. It is also stated in <R65>:
The fuse on the Spike relay for the air compressor may be replaced with a 20 Amp Snap-Action circuit breaker.
The issue is the inrush current on the Thomas Compressor.
Note that this is the only Spike that can be modified in this manner...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 24-01-2007, 14:26
void* Jake;
FRC #1178 (DURT)
Well, that would do it. We haven't used any pneumatics in the past three years. That might be how we missed it. Thanks guys.
Code:
void function(void)
  function();
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
programming the compressor archiver 2001 4 23-06-2002 23:19
Wiring Compressor DakotaFox Electrical 3 05-02-2002 16:52
