Go to Post Probably planning on milling the bumpers out of solid pool noodle stock, too. Ever wonder how they drill that hole down the middle of pool noodles? ;) - Bill_B [more]
Unread 25-01-2007, 08:20
HellBoy HellBoy is offline
FTC #2230
HellBoy is an unknown quantity at this point
The camera's range of vision
I need to find out what is the vision range of the camera in degrees.
Thank you.
Unread 25-01-2007, 11:18
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: The camera's range of vision
Point the camera at something. Use the LabView camera application to capture a frame. Match up what you see at the edges of the picture with points in real space. Measure it. Voila! You'll have your answer, and it will be correct for your camera.
Camera's battery Max Brin Technical Discussion 1 19-02-2006 15:28
Using VEX range finder on the full-size FRC CronosPrime1 Programming 3 08-02-2006 23:29
Camera's Field of View? Greg Marra Programming 1 26-01-2006 13:17
Camera Vision Range Muhnki Programming 7 05-02-2005 23:26
