what is the pressure switch?
how is wired
Re: what is the pressure switch?
You take a PWM cable and use two of the wires to wire to the switch. Everybody uses digital in/out 18.
caraddicted is right, If I recal it should be the white and black wires that you use. The only reason people use digital input 18 is because it is set up to turn off the last relay (I forget the number) in the default code. Basically, if you plug the switch into dig in 18 and the compressor spike into the last relay you dont need to change any code. |
| [OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. | BrittanyV | OCCRA | 3 | 16-10-2006 15:42 |
| PRESSURE SWITCH | Mr. Steve | Pneumatics | 20 | 01-12-2005 10:20 |
| pressure switch | Michael Long | Pneumatics | 1 | 11-02-2003 11:21 |
| pressure switch | piconysm | Technical Discussion | 5 | 14-02-2002 23:15 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
