Go to Post Okay, Okay, I officially apologize to the the entire country of Canada - Joe Johnson [more]
Unread 25-01-2007, 18:32
Reaper40's Avatar
Reaper40 Reaper40 is offline
FRC #2061
Team Role: Webmaster
Reaper40 is an unknown quantity at this point
how do u wire double solonoid valve?
the double solonoid valve requires 24v and the spike can only take in 12V so i dont know what to do?
Unread 25-01-2007, 19:05
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: how do u wire double solonoid valve?
If I'm not mistaken doesn't the Solenoids get pluggend into one of the Digital / Analog inputs on the RC and then from the RC it goes to the Relay via a PWM Cable. It should be in the wiring schematic thats in the manual.
Edit: Ok so I was wrong on that one =) My bad!
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
You should change the coil to 12 VDC.
* You must remove the 24V coils from the solenoid valves and replace them with the grey 12V coils before installing them on your robot. This is done by removing the mounting screws, and switching the 24V coils for the 12V coils provided. More information about these valves is provided in the FIRST 2007 Pneumatics Manual posted on the FIRST website: http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
The SMC Pneumatics kits have been sent to your team’s Shipping Contact as entered in your TIMS record. The contents of the kits are listed below:
- QTY 1: Straight fitting, male, 5/32" tube, 1/8 NPT (PN KQ2H03-34S)
- QTY 1: Elbow fitting, 90, 5/32" tube, 1/8 NPT (PN KQ2L03-34S)
- QTY 5: Elbow fitting, 90, 1/4" tube (PN KQ2L07-34S)
- QTY 10: Straight fitting, 1/4" tube (PN KQH07-34S)
- QTY 10: Elbow fitting, 90, 1/4" tube (PN KQLO7-35S)
- QTY 5: Tee union, 1/4" tube (PN KQTO7-00)
- QTY 6: Flow control (PN NAS2201F-N01-07S)
- QTY 2: Sub base, 1/8” ports (PN SY3000-27-1T)
- *QTY 2: Double solenoid valve, 24VDC (PN SY3240)
- *QTY 1: Single solenoid valve, 24VDC (PN SY3140)
- *QTY 5: 12VDC replacement coils (PN SY114-6LOZ)
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 25-01-2007, 19:08
caraddicted101 caraddicted101 is offline
Rookie Year: 2000
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
We took both positive wires and attached them to the positive and negative connections on the spike. The negative wires from the solonoid go to the negative part of the breaker panel. This way when you apply power the air goes one way, and when you reverse the power the air goes backward.
Unread 26-01-2007, 00:15
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Hi caraddicted101, Are you sure that's allowed? The wiring diagram shows both wires to a solenoid connected to a spike. Have you been through an inspection in previous years with it like that. I know, electrically its fine, just don't want to get stuck in inspection.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 31-01-2007, 12:57
FrontiEErsman FrontiEErsman is offline
FRC #2177
FrontiEErsman is an unknown quantity at this point
Are any other teams doing this / thinking about doing this? I believe someone else on my team is posting a question to the Q & A, so hopefully we can get an official ruling.
Unread 31-01-2007, 14:51
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Talking Re: how do u wire double solonoid valve?
We have used it every year that we used pneumatics. It is very useful.
The two wires go to the positive and negative ends of the spike. Single solenoids only provide a momentary switching which is useful for some applications but not for something such as a claw to grab ringers.
Just depends on the application.
The manual is very clear on how to wire.
Unread 31-01-2007, 16:20
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
I was looking into this today to see if I could use 1 double action solenoid to control two different cylinders. In the past, we had wired them by connecting the negatives to ground. Then I found that the Spike User guide states it that way also. http://www.ifirobotics.com/docs/spik...uide-sep05.pdf
Unread 01-02-2007, 16:03
jcatt's Avatar
jcatt jcatt is offline
AKA: Jonathan Catt
FRC #1902 (Exploading Bacon and FRC #1251 TechTigers)
jcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of lightjcatt is a glorious beacon of light
My team and i have a question. Can you connect both negative ends of the valve to the same crimp terminal to save space on the fuse pannel. The wire is so small of awg that "electricaly" it would be possibe, BUT is it allowed in the rules.
Jonathan Catt
Co-Owner and Systems Architect of ColorScene Inc.
Co-Sponsor of The RoboShow: Orlando
FRC 1251 Alumni
FRC 1902 Mentor
Unread 04-02-2007, 18:13
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
We also have played with wiring both parts of the valves to a single spike, although, you can't simply put the positive of one and negative of the other into one end of the spike and the negative of the first one and the positive of the second into the other end of the spike. Oddly, if you wire one end of the valve backwards (positive to the black wire and ground to the red) it still works as if you wired it correctly, which means no matter which way the spike is sending voltage, both sides are active and fighting against each other. At least that's how it works with the valve we're using. So, you either need to use some diodes to prevent backwards current, or my idea.
The idea I came up with, and I'm probably not the only one, is to wire the positive of one side of the valve to M+ of the spike and the positive of the other side to M-. Then wire the negatives of both ends of the valve to a separate wire, which goes straight to ground on the power distribution panel. You still need both a negative and a positive input to the spike, to keep it running. There must be a capacitor on the spike, because it will work once and only once without a negative input.
Anyway, is it legal to run both ends of a valve from one spike? I know rule R91 says, "Each motor, actuator, and compressor must be connected to one, and only one, speed controller or relay module." Does each end of the valve count as one acutator, or does the valve as a whole count as one? Secondly, is there anything wrong with my solution to running a valve from one spike?
Code:
void function(void)
  function();
Unread 16-02-2007, 14:48
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Re: how do u wire double solenoid valve?
It is clear in the Spike manual linked above that what you said is a legal option for wiring the double solenoid. However, does anyone have any ideas on how to mount it onto the robot as that is also a regulation. also, does anyone know what the side threaded openings labeled "X" and "PE" are? I was thinking they might be vents for exaust but then what would the "EB" and "EA" openings be for? any suggestions? Thanks!
Yes, Spanky
Unread 16-02-2007, 15:24
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
"X" and "PE" are not used. "EA" and "EB" are the exhaust for the A and B ports. They do not need anything hooked up to them.
You can run a secondary regulator between the main regulator and the P port for both A and B regulation or in series after A or B for regulating the pressure on just one side of the cylinder. The flow regulators go on the cylinder and control flow out of the cylinder.
We also wire the red leads (one each) to the M+ and M- on the spike and run the blacks together to the negative part of the breaker panel.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 17-02-2007, 18:49
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
Infuriating....
I also needed to wire a double solenoid valve and used the above suggestionis.
I can only move the piston out, however.
Can any body help?
Unread 24-02-2007, 17:44
Jeremytice's Avatar
Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
We have done the same for a couple of years. It is very useful. I would tell you more but it sounds like everyone else has covered what I would have said. Good luck!
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
SMC Double Action Valve. Josh Hambright Pneumatics 2 14-02-2003 10:24
SMC Double Solenoid Valve Assembly Dave Kempskie Pneumatics 0 29-01-2003 13:34
Will trade for double solenoid valve archiver 2001 2 24-06-2002 00:33
