Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 25-01-2007, 19:21
Breeze Breeze is offline
FRC #0280
Breeze is an unknown quantity at this point
Question liquid electrical tape
Team 280 want's to know if using liquid electrical tape is aloud. Using electrical tape is aloud but we don't if it applies toward liquid electrical tape?
Would someone Help us with this problem. We would appreciate the help. thanks.
Unread 25-01-2007, 19:54
Danny Diaz's Avatar
Danny Diaz Danny Diaz is offline
Smooth Operator
AKA: FrankenMentor
None #0418
Danny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond reputeDanny Diaz has a reputation beyond repute
Send a message via AIM to Danny Diaz
Re: liquid electrical tape
I don't know if liquid electrical tape is legal this year, however we used it 3 years ago on our robot and learned a very valuable lesson: don't. The stuff smells, is very unmanagable, and is only really necessary in a very small subset of circumstances. If you cannot do what you need to do with real connectors or regular electrical tape then you might want to consider doing it differently. While we were allowed to use liquid electrical tape that year, at the end of the day we really wished we hadn't and vowed to never let that vile stuff into our shop ever again.
-Danny
Danny Diaz
Former Lead Technical Mentor, FRC 418
Unread 25-01-2007, 20:33
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
I agree with Danny. You can use it buy why would you want to?
A good supply of heat shrink tubing and regular electrical tape should be all you need.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 25-01-2007, 20:45
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
We have used liquid electrical tape and the inspectors have loved it !! We cover all terminals with it. It is much easier than shrink wrap in certain situations and much easier to make repairs. We plan on using it again this year.
Unread 25-01-2007, 23:06
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I wouldn't say that inspectors actually 'love it'. I have allowed it in the past when it is used in place of electrical tape, i.e. insulation and that it is correctly applied. Know that if you need to remake a connection once it is covered, the only right way is remove with paint remover which is not allowed in the pit. Heatshrink is so much nicer and there is no drying time to worry about.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-01-2007, 23:24
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
to secure the connection between the terminal and the pwm we usually put some hot glue. If done properly it can look decent and if for whatever reason something needs to be changed or fixed you can just pull off the hot glue with some needle nose pliers.
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 25-01-2007, 23:33
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
FRC #0025 (Raider Robotix)
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
I'm not familiar with liquid electrical tape, but is it visible? If not--then how do you know if it's present or not--that sounds like an awfully bad idea to me
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
Unread 26-01-2007, 00:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
It comes in at least black and red. Probably in other colors too.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2007, 00:17
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
sounds interesting... but i wouldn't.
i second the hot glue suggestion... that liquid electrical tape is very nasty stuff.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 26-01-2007, 01:17
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
We've used it on the connections with the 6 guage wire from the battery. The inspectors always want those taped, are never happy with the tape job, it's hard to tape neatly, and the liquid tape does a good job. It you don't like the smell, just do it before you leave for the night and let it dry overnight. Usually, takes at least two coats on the heavy terminals.
Unread 26-01-2007, 03:18
SPARKY1688's Avatar
SPARKY1688 SPARKY1688 is offline
AKA: Marko Rajacic
FRC #1688 (StickShift)
SPARKY1688 will become famous soon enoughSPARKY1688 will become famous soon enough
I am glad that somebody started this post because I walked in our lab and one of the menors purchased that stuff and i was gonna use use it but i changed my mind.
Keep it simple is always best.
Thanks,
Marko
Unread 26-01-2007, 09:34
DRH2o's Avatar
AKA: Dan Waters
Let me add to what I said before. We use it in places that are hard to tape or apply shrink wrap. Terminals with odd angles or hard to reach spots. You can remove it without paint thinner. Everything has its place and used correctly this stuff is good.
Unread 27-01-2007, 21:55
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
I've used it in project boxes to make sure that pins I solder to an IC don't short.
But that's about it.
Liquid water on Mars?? di_zou Chit-Chat 6 06-12-2006 17:22
Electrical tape as a non-functional decoration Cody Carey General Forum 14 03-04-2006 00:07
NASA: Liquid water once on Mars Clark Gilbert NASA Discussion 9 03-03-2004 02:31
Hot Glue/Electrical Tape Jeff Zampieron Electrical 7 25-02-2004 03:52
Liquid Nitrogen Ice Cream Ian W. Chit-Chat 12 11-08-2002 19:05
