Go to Post You can usually pick out the kids who will grow up to be engineers. They're the ones tearing apart their nintendo, their vcr, their minibike, and their parents' cars. - Tom Line [more]
Unread 25-01-2007, 19:34
Andrewpbhs's Avatar
Andrewpbhs Andrewpbhs is offline
FRC #2023 (PiraTech Engineering)
Andrewpbhs is an unknown quantity at this point
Parts for Green light
We are looking for 4 parts to build the green light. Defuser panel, Aluminium Chassis Modual, Bracket CCFL, and Bracket Target mounting.
Help would be much appriciated
Unread 25-01-2007, 20:54
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Parts for Green light
Two diffuser panels were in the Kit of Parts. You will need to make the box and the mounting brackets. Some teams have made workable boxes out of wood lined with aluminum foil.
Unread 25-01-2007, 20:59
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Heh, our team didn't use any of that. We managed to make a working box out of wood, aluminium foil, and wire ties. But hey it works and the camera has no problem tracking it.
Amperage Robotics Team 1225
Site under-going revamp. :/
Green light same color as overhead light Ethulin Programming 13 02-08-2007 15:24
Green light Case Lablabla Technical Discussion 9 16-01-2007 21:53
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
KOP green light 987HighRoller Kit & Additional Hardware 1 13-07-2006 23:18
Green Light Rachika Garcia Kit & Additional Hardware 1 10-01-2006 08:46
