Go to Post Don't waste the opportunity because you were too focused on "winning" the championship. - Don Wright [more]
Unread 26-01-2007, 15:13
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Fork Connectors
Hello all,
We've gotten our electronics wired up using standard fork connectors on the victors. I was wondering if there is any reason we shouldn't use the fork connectors. One of our members thinks that they will cause a problem... but I don't forsee any.
Any advice is Greatly appreciated
-Cody C
Unread 26-01-2007, 15:25
Peter Matteson's Avatar
Peter Matteson Peter Matteson is offline
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Peter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond reputePeter Matteson has a reputation beyond repute
Re: Fork Connectors
Ring lugs are less likely to come loose if the wires are accidentally pulled. I would be more comfortable using them than fork style.
2011 Championship Finalists/Archimedes Division Championships w/ 2016 & 781
2010 Championship Winners/Newton Division Champions
Thank-you 294 & 67
2009 Newton Division Champions w/ 1507 & 121
2008 Archimedes Division Champions w/ 1124 & 1024
2007 Championship Winners/Newton Division Champions w/190, 987 & 177 The Wall of Maroon
2006 Galileo Division Champions w/ 1126 & 201
www.bobcatrobotics.org
"If you can't do it with brains, it won't be done with hours." - Clarence "Kelly" Johnson
Unread 26-01-2007, 15:26
Jeremytice's Avatar
Happy Birthday! Jeremytice Jeremytice is offline
Addicted to FIRST!
FRC #1126 (SparX)
Jeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to allJeremytice is a name known to all
Send a message via AIM to Jeremytice
Re: Fork Connectors
Hey Cody,
I dont forsee any problems using the fork connectors. I would just make sure that you check them continuesly just in case the screw starts coming loose on the victors. Other than that they should work pretty good. Last year we used these 90 degree terminals and they worked great.
2006 SparX FLR champions with 229 and 1567 after being seeded 1st and Radio shack innovation in controls at FLR
2006 Galileo Division-DIVISION CHAMPION (thanks to 177 and 201)
2006 BattleCry great alliance 1519 and 195.
2006 RCCR hometown champs with 378 and 2567
2007 FLR Innovation in Contols award
2007 Buckeye General Motors Industrial Design Award
2007 Buckeye Finalist with 1038 and 1528
2007 Galileo quarterfinalists with 229 and 191
2008 FLR finalists with 378 and 1551
2008 Buckeye Champs with 1024, 1386, and 2048
2008 Buckeye Motorola Quality Award
2008 IRI Finalists with 1024 , 1625, and 1731
Unread 27-01-2007, 11:26
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Fork Connectors
Cody,
The design of the Victor and the power input to the RC can cause problems with fork connectors if they are not checked by your electrical pit crew on a regular basis. Often, over tightening the mounting screw will spread the forks and cause the distance between adjacent connectors to shrink. We use a push on adapter that is designed with a screw hole at one end and a push on at the other end. This way, damaged components can be replaced without tools and electrical check time is vastly reduced.
Al
WB9UVJ
www.wildstang.org
________________________
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
the FSK show (fork, spoon and knife show) Psalms(118:6) Rumor Mill 0 23-04-2004 08:33
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Fork Lift Robot tinyfarnsworth General Forum 64 16-04-2002 12:09
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
