Buying steel #25 sprockets
I'm looking for steel, flat, #25 pitch sprockets in 48 and 70/72 tooth.
Mcmaster only has these with hubs. I need them to be flat so because they will be welded onto a tube. We can buy the hubed ones and machine them off, rebore them and try to find a way to weld the hardened steel, but I would rather just buy the right thing in the first place... so... where should I look? |
Re: Buying steel #25 sprockets
SDP-SI has them in carbon steel.
That's http://www.sdp-si.com just in case Google is suffering from amnesia.
Check out Motion Industries.
Part# 25A40 pitch (A)hubless/(B)hubed number of teeth Martin's Sprocket Catalog Check out page 16. Last edited by Kirk : 27-01-2007 at 17:38. |
| Welding stainless steel to mild steel... can it be done? | Travis Covington | Technical Discussion | 3 | 27-01-2004 19:11 |
| Steel Blends | Wetzel | Technical Discussion | 2 | 15-09-2003 17:01 |
| steel tubing | BBFIRSTCHICK | Rules/Strategy | 2 | 14-01-2003 22:03 |
| Legality of steel tubing. | newy | Rules/Strategy | 3 | 01-02-2002 09:16 |
| Steel Edge | AJ Howard | Rules/Strategy | 1 | 18-01-2002 18:52 |
