Go to Post I never cease to be amazed at the creative engineering employed by some teams. - Karthik [more]
Unread 26-01-2007, 21:28
marcan marcan is offline
AKA: Hector Martin
FRC #2117 (Wolvotics)
Rookie Year: 2007
marcan will become famous soon enoughmarcan will become famous soon enough
Digital to OI Analog
Has anyone tried interfacing digitally generated signals to the OI? Everyone seems to be using potentiometers like the original joysticks, but using a DAC is obviously possible (see the USB-Chicklet). Does anyone know what the requirements are for the analog inputs of the OI? Given a schematic of the OI input section it should be very easy to design a circuit that works as intended, but I need to know what the inputs rely on to tell what the joystick value is.
My guess is they have a fixed resistor to GND and use the pots (wired to +5 on the joystick) to form a voltage divider, which is then measured using a PIC's A/D converters. In this case, driving a constant-voltage output (buffered using an op-amp if needed) would essentially make the resistor meaningless and allow you to directly control the input proportional to the applied voltage (from an A/D converter, for example). However, many other input systems are possible, including using capacitors to form an R/C circuit and measuring the time it takes to charge/discharge, or using a more complicated arrangement with resistors.
Has anyone taken apart their OI? I'm going to assume it's been the same over the past few years. A schematic or picture from the input section of a 2005 OI would be awesome
Analog-to-Digital Converter Code Kevin Watson Programming 29 17-02-2008 13:07
Analog to Digital Conversion Help Der Rowan Programming 4 23-01-2006 00:17
Accelerometer: Analog or Digital? psquared Programming 2 10-02-2005 16:38
Analog / Digital IO Connectors Aidan F. Browne Control System 4 06-02-2005 22:26
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
