Go to Post With any dollar amount to invest I would be more interested in the number of individuals (students is too narrow) impacted than the number of teams created--after all, this is about people. - kramarczyk [more]
  #16   Spotlight this post!
Unread 29-01-2007, 00:21
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: small banebot motor with 64:1 gearbox
We are using two 64:1 42mm Gearbox w/ the FP motor to power our forklift. Two 64:1 36mm Gearboxes will be powering the "arm".
We'll tell you how well it goes later this week. We realized the best way to see if it'll work is to try it, then go from there. If there isn't enough torque, then we'll get different gearboxes.....
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
  #17   Spotlight this post!
Unread 29-01-2007, 01:48
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by Jonathan Norris View Post
I wouldn't be surprised for it to burn up just like the FP motor, most small high RPM motors will have that same problem. This new motor looks just like a weaker FP motor. You would be better off with approx. twice the torque with the FP motor, and a 42mm banebots gearbox. I am liking this 256:1 42mm gearbox to attach a FP motor for an arm.
Team 294 agrees with you.... Three times to be precise....
Low enough gearing combined with a PID algorithm (which is much simpler than you may think) will work.
opening up the BaneBot gearbox to install the CIM motor jskene Motors 9 22-01-2007 11:12
Banebot Gearbox chris31 Technical Discussion 45 15-01-2007 17:56
56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? VEN Technical Discussion 4 11-01-2007 14:45
Drill Motor Max RPM with Gearbox? archiver 2001 1 23-06-2002 22:40
What with the small motor? Robb Gerber General Forum 10 10-01-2002 14:10
