Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 26-01-2007, 23:38
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Our Camera doesn't Detect
Our 2007 Controller was broken so we are using 2006 micro-controller. I downloaded Kevin 2007 Camera code in 2006 controller. I attached Pan - pwm -01 and Tilt - 02. I connected the camera on a TTL and attached it with to a camera with using pwm cable. Than i connect a pwm cable to power camera on pwm pin 3. However, the camera doesn't turn on [No green light]. I take the pwm cable out of pin 3 and put it on analog 1 and the green light turns on
Now the camera shows "Searching" on terminal window. However, the pan and tilt servo's don't move. Can someone please tell me what mistake we might be making.
Unread 26-01-2007, 23:54
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: Our Camera doesn't Detect
One thing I would look for is the jumper on the camera. If you go here and scroll down to page 5 of section 2, there is a picture of the board. You will notice a section on the left called "Servo Power Source". You will notice that a jumper is usually closed on the internal power source, while the external is not. Try moving the jumper to the external power source and see if that helps.
Unread 26-01-2007, 23:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The symptoms are clear and specific: you have no power on the 7.2v pin on the pwm connector. Is your backup battery charged and connected? That's where the servo (and camera) power comes from.
Unread 27-01-2007, 13:45
Jigar Patel
AKA: Jigar Patel
Yes definetly our backup batter is fully charged. However its just not moving the servos which I find annoying.
So what happend with our camera? Rombus Programming 12 19-03-2006 00:34
Camera Config doesn't save! comwiz7 Programming 2 20-02-2006 17:19
Camera doesn't have firmware? no programming? GraphicArtDesig Programming 6 19-01-2006 20:10
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
Minor Problem, our robot DOESN'T work! Cobra Motors 1 15-02-2003 14:43
