Pressure Switch Wiring
I am not sure how to wire in the pressure switch for the pneumatics. The switch has two terminals the PWM digital has three. Do I use just the ground and positive?
Thank You |
Re: Pressure Switch Wiring
You should connect the black wire to the C terminal, and the white wire to the NC terminal. The red wire is not used for hooking up switches.
EDIT: There is more info on page 9 of this document: http://www.ifirobotics.com/docs/rc-r...-6-13-2006.pdf Quote:
| Need Help Wiring Micro Switch/Limiting Switch | Windward | Electrical | 2 | 07-02-2006 18:26 |
| PRESSURE SWITCH | Mr. Steve | Pneumatics | 20 | 01-12-2005 10:20 |
| Pressure Switch wiring diagram | robotjoe | Electrical | 1 | 08-02-2005 14:01 |
| Pressure Switch Wiring Question | Matthew_H | Electrical | 4 | 16-02-2004 01:25 |
| Pressure Switch Wiring Question | Matthew_H | Control System | 1 | 08-02-2004 15:28 |
