Go to Post IYou might get it all changed over and discover your robot has trouble moving from a dead stop, can no longer turn without playing morse code on the breakers... - KenWittlief [more]
Unread 27-01-2007, 12:02
Demothesis's Avatar
Demothesis Demothesis is offline
Team Leader/Programmer
FRC #2169 (KING TeC)
Team Role: Leadership
Rookie Year: 2007
Demothesis is on a distinguished road
Red face Camera servo trouble
I know that you are supposed to connect the servos on the camera to the PWM ports, but for whatever reason, they don't work. Perhaps it has something with the program code. Do I need to write special code? I hooked up the servos to ports being controlled by the joystick, thinking that they would respond to the pulses, but without success. In fact, in furter trouble shooting, I discovered that the power pins on the PWM ports didn't even produce voltage! (from multimeter tests) The strage thing is, the victors still work on them....
If it's the wiring, could you suggest possible programming techniques please?
Demothesis
Unread 27-01-2007, 14:44
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Camera servo trouble
The most common reason for this kind of problem is failure to connect the backup battery to the RC.
Unlike all the other I/O connections on the RC the PWM power comes solely from the backup battery.
Your servos won't run without it, but the Victor's will operate just fine because they don't actually use the PWM power (having plenty of 12v power of their own).
Unread 27-01-2007, 15:03
Syncopation's Avatar
Syncopation Syncopation is offline
I can't make a dongle outta 25-pin!
FRC #0932 (Memorial Circuit Chargers)
Syncopation has a spectacular aura aboutSyncopation has a spectacular aura aboutSyncopation has a spectacular aura about
Send a message via ICQ to Syncopation Send a message via AIM to Syncopation Send a message via MSN to Syncopation Send a message via Yahoo to Syncopation
I agree with Mark. Testing the camera will probably involve having a spare backup battery, as a few good session can drain it.
Also, you might check Kevin Watson's site (kevin.org/frc) for affirmation that you're hooking up the PWMs correctly. He hosts a great step-by-step walkthrough of hooking up the camera.
Unread 27-01-2007, 15:16
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Demo,
Before you say you had the backup connected, I must add that the backup battery comes discharged. You need to charge it overnight before you use it the first time. How are things up north? We had relatives in Minnetonka until last spring.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-01-2007, 15:49
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
From my experiance, I've found the servos given to us are crap. This year the servo we were given didn't even work. It kept forcing the servo to move up. When we plugged in another servo on the PWM it would operate just fine. If all else doesn't work, its broke. We had to disable last year's camera and take the servo.
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 27-01-2007, 17:15
Demothesis's Avatar
Rookie Year: 2007
Hey guys,
Thanks for the info. We don't have an Internet connection at the build-site , so I am doing all my Internet stuff at home. Anyway, it seems like what you suggested should work. I know MY servos aren't broken because I took them home and tested them on my trusty BASIC Stamp . Yeah, it's BASIC, but it does the trick.
By the way, things in the north are great! We have had a really weird winter like everyone else (almost NO snow ), but it's finally getting cold. Tonight it's supposed to get down to zero deg. F.
Honestly, Demothesis
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
Servo Strain With Camera DanDon Motors 6 13-02-2005 08:49
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
Camera Servo Obi Programming 2 30-01-2005 17:09
