Go to Post The [FIRST Robotics] competition is a friendly / gentleman's sort of sport... It is only a forum to put our machines to the test, and see how well we did against what WE set out to do -- not to see which team can build the best robot. - KenWittlief [more]
Unread 27-01-2007, 14:51
bilal1219's Avatar
bilal1219 bilal1219 is offline
AKA: Bilal
FRC #1219 (Iron Eagles)
bilal1219 is an unknown quantity at this point
Question on the code
Hello everyone,
Can you plz tell me if i can run my 2006 FRC code onto 2004 controller just for testing. if yes would i have to change my OI of 2006 to 2004.
Thank you very much
Bilal Shahid
Team 1219
Unread 27-01-2007, 14:58
Syncopation's Avatar
Syncopation Syncopation is offline
I can't make a dongle outta 25-pin!
FRC #0932 (Memorial Circuit Chargers)
Syncopation has a spectacular aura aboutSyncopation has a spectacular aura aboutSyncopation has a spectacular aura about
Send a message via ICQ to Syncopation Send a message via AIM to Syncopation Send a message via MSN to Syncopation Send a message via Yahoo to Syncopation
Re: Question on the code
Everything is basically the same (might be some differences in firmware, but I've never encountered any problems with doing that). You will have to change the "Robot Controller Settings" under "Options" (from "FRC 2006/2007" to "FRC 2004/2005"), assuming you're using EasyC. Not sure how it would work with MPLAB.
Unread 27-01-2007, 15:44
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Download the 2006 code and look at "Using_Last_Years_FRC.txt" and try to backtrack all the changes they've made. If you didn't do large ammounts of code you can possibly just copy and paste it.
Amperage Robotics Team 1225
Site under-going revamp. :/
2007 IFI default code question Japper Programming 4 22-01-2007 23:23
are we using the right code? (was: Simple question..) Absolute0 Programming 2 23-01-2006 14:24
question about the code naor52 Programming 1 10-01-2006 16:42
Question about kevin's code ImmortalAres Programming 3 23-06-2005 11:13
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
