Go to Post Pretty robots, who cares? Quality robots are another matter. - Steve W [more]
Unread 27-01-2007, 18:50
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
AndyMark Mecanum
Hey!
We bought and assembled 4 AndyMark mecanum wheels.
The rollers seem to be tight, as in not turning well, therefore prohibiting the robot to 'crab walk'. Our next step would be to add a couple of washers to the six center spacers to ease tension on the rollers. Has anyone else come across this problem? Has anyone tried any type of lube (don't want to make our $$ wheels all messy unless if we have heard someone else has tried it )
BTW, I'm not on the mechanical team. I just need these wheels done and mounted so I can start programming, so I've decided to take the initiative to getting that done sooner.
Jacob Komar
Unread 27-01-2007, 18:52
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: AndyMark Mecanum
Yes. We have come across the same problem. You can loosen the screws, but I'm sure you've tried that already.
This may take quite a bit of time, but during assembly or the production of the plates, some of the tabs might have been bent a little bit too much or too less. So, someone would have to go in with a pair of pliers and bend the tabs such so that the wheels spin freely.
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 27-01-2007, 18:57
AKA: Jacob Komar
Sweet.
Thanks. It sounded like it would work, but it just seems so time consuming... I spent 2 hours today simply swapping out 4x6 (24) bolts in the center of the wheels because they were too long. I just wanted to make sure there wasn't a faster way...
OK. This is what I need.
Thanks again,
Jacob
Unread 27-01-2007, 21:26
Gurdian Gurdian is offline
Lord Protector
AKA: Ryan Fender
FRC #1730 (Team Driven)
Team Role: Leadership
Gurdian will become famous soon enough
Send a message via MSN to Gurdian Send a message via Yahoo to Gurdian
Ya... we came across the same thing. Kinda wondering if one or more of the jigs or presses isn't set right and causing mechanical difficulties on the back side. On the next note, does anybody know how fast those rollers wear. We've ran our frame for several hours and we are noticing some wear, more than what I had expected.
Nuts
-Gen. McAuliffe, Winter 1944
Unread 27-01-2007, 23:44
We've been driving this thing for at least an hour every day for a week and I haven't seen any problems with the rollers wearing down. Are the rollers really loose or do they stick in place?
Unread 27-01-2007, 23:57
AKA: Jacob Komar
Yeah... We ran ours for about 15 minutes and started to notice the rubber starting to *chip* (not sure of the technical word...) Granted, our rollers aren't fixed yet and are dragging on the floor, and we haven't tried it on the carpet yet, just simply using tile floor.. But still, they seem to wear fast.
We will fix the rollers on Monday and I'll let you guys know exactly how we did it so that other teams with the same problem can fix theirs. Sunday is our day off (mine at least )
Jacob
andymark? Ian_Xodus General Forum 9 18-01-2007 22:08
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
pic: AndyMark Mecanum Wheels Madison Technical Discussion 13 09-10-2006 00:29
AndyMark Mecanums Joe_Widen Technical Discussion 10 05-09-2006 22:12
Andymark.biz Andy Baker Technical Discussion 119 01-05-2006 23:30
