Go to Post What Delphi says doesn't matter. What the official Q&A says matters. - Tetraman [more]
  #16   Spotlight this post!
Unread 29-01-2007, 19:56
Ted_Z Ted_Z is offline
FRC #1348 (Commanders)
Ted_Z is an unknown quantity at this point
Re: Looking for a keyed sprocket
These steel sprockets are made by Grizzly with hardened teeth. I've used them with good success. They are only $2 because they are a surplused item.
I'm sure having a broach set will come in handy though.
-Ted
#1348
JFK HS, Denver, CO
  #17   Spotlight this post!
Unread 30-01-2007, 14:45
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
Rookie Year: 2000
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
To accomplish without a broach insert a steel shaft in the hole - center punch and then drill a 1/8" hole - insert a steel pin and voila' keyed shaft that holds as well as square - we have used this technique successfully. I pulled it off of a machinist forum a few years back.
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Key for Transmission > sprocket location mrhankeydapoo Motors 4 08-01-2007 19:15
[OCCRA]: Trade for 45-Tooth Sprocket (x2) Silent_Stryker OCCRA 0 27-09-2006 13:25
Keyed Axles aznium Kit & Additional Hardware 4 03-02-2006 19:24
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
Skyway keyed hubs sanddrag Technical Discussion 0 28-02-2004 21:57
