Re: 2007 Scouting Sheet
We are scouting on a robot/round basis rather than a robot/regional basis. We put all of the information for that round for a particular robot on 1 sheet (1/3 of a sheet) and when done, file it away.
Later that night, I combine all of the data and put it in an excel file for easy viewing. It is our first year trying this system so hopefully it will work out. -Andy |
We have an Excel spreadsheet which anyone is welcome to use. The fields highlighted in yellow are editable, while the others use formulas.
I'm currently working on a scouting sheet, but I still need a little help. I was wondering if anyone had any ideas for the matches, as to how I can create a scouting sheet for that. I'd really appreciate it a lot. Thanks a lot.
What are the robots supposed to do? Break that down into individual tasks, then put those tasks into an Excel spreadsheet or something similar. Weight each item depending on your robot's capabilities and you're all set, other than giving a copy to each of six match scouts.
I finished ours today, basic simple one, it has worked great in the past. |
Typically teams use pit scouting info just as a quick reference and treat it as secondary to match scouting. THe more info you have the less often you need to send some one to get more info right before a match.
that is true, but having a separate scouting sheet for the matches and for the pit area is also helpful when looking at alliances because the scout can see if what another team said about their robot was really true. you know, if the robot succeeded its expectations.
http://www.chiefdelphi.com/media/papers/1926
Here's what 662 will be using. Focus is on significantly reduced paper-work, ease-of-use, important information available at a glance, and aesthetic appeal. |
| Scouting Sheet | astephen68 | Scouting | 30 | 26-03-2007 19:45 |
| paper: Rat Pack and Mech Warriors Match Scouting Sheet, Revised | Lisa Perez | Scouting | 1 | 08-03-2006 09:00 |
| White Paper Discuss: AIM HIGH SCOUTING SHEET UPDATE 1 | Tomasz Bania | Extra Discussion | 4 | 21-02-2006 17:17 |
| White Paper Discuss: 222 Aim High Scouting Sheet | henryBsick | Extra Discussion | 1 | 09-02-2006 14:53 |
| White Paper Discuss: 2006 Aim High Scouting Sheet Extended | Tomasz Bania | Extra Discussion | 3 | 03-02-2006 14:55 |
