Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 01-28-2007, 06:46 PM
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
rule <g29> and flag
does our flag count toward dimensions on our robot? we were thinking about making a robot 36" but the flag would go over the 38" rule, allowing for us to stay upright instead of sitting on end, as stated by gdc in the q&a forums here. does this violate rules or isnt ethical or doesnt count? or is it legal?
Unread 01-28-2007, 06:49 PM
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
Team Role: Mechanical
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: rule <g29> and flag
well, first of all, i would guess that you meant that the rule was 48 inches.. because it is, and no, the flag does not count as the overall hieght.
Unread 01-28-2007, 06:55 PM
gondorf's Avatar
no i meant as in that since the longest dimension has to be the vertical one at the beginning then that means that a 28*38 robot that is 36" high must start on the 38" side. with this i mean that first of all which side do they want the flag on since a flag holder modified to change the orientation of the flag would likely be illegal so if we end up changing the "vertical" side of our robot then which side would it have to be on? and second does the flag (something that would put said 36" robot over 38", therefore making the other side the max dimension and totally putting the rule out of wack) change the sizing?
Unread 01-28-2007, 08:58 PM
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
From <R11>:
The FLAG is not considered part of the ROBOT. However, the flag holder specified in Rule <R15> IS considered part of the ROBOT, and is included in the weight and volume determination.
and from <R15>
The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is a minimum of 18 inches higher than any point on the central mass or structure of the ROBOT
Any other questions?
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 01-28-2007, 10:43 PM
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
They even state in the Q&A that if flopping is an issue then make a mast higher than your length an then you wouldn't have to flop over.
We do not stop playing because we grow old;
we grow old because we stop playing.
Rule G29 stillwaters130 Rules/Strategy 3 01-08-2007 06:14 PM
rule G20 and G48 paradoxal Rules/Strategy 13 01-08-2007 08:22 AM
Rule G11 and Springs Rule mtaman02 Technical Discussion 3 01-23-2004 05:43 PM
seat motors and rule M1 Matt Krass General Forum 5 01-06-2003 08:42 PM
IMPORTANT RULE ADDITION AND CLARIFICATION Mike McIntyre OCCRA 0 12-03-2001 10:17 PM
