Banebot 56mm gearbox - double D related
There are threads here, here and here that are all discussing the same issue. Will the double D joint between the last carrier and the output shaft survive?
There are sub-questions: Will the 12:1 1 CIM joint fail? If so what can be done to fix it? Will the 16:1 1 CIM joint fail? If so what can be done to fix it? Will the 12:1 2 CIM joint fail? If so what can be done to fix it? Will the 16:1 2 CIM joint fail? If so what can be done to fix it? We can debate who is to blame and how could this have happened all day long. It is not going to get us the answers to the question, nor is it going to get us to a solution. Here is the state of things: Data Point 1: Hardness test of shaft and carrier: Output shaft: RC 23, RC 23.3, RC 23.2 Rockwell C to Tensile Yield: Rockwell A to Tensile Yeild:Data Point 2: Calculations & Date = Prediction Using calculations + above hardness tests of the joint, I predicted that with the 12:1 gearbox should fail at about 3.1N-m input into the gearbox. Since 3.1N-m = 28in-lbs = roughly 1.5X CIM_stall_torque, alarm bells began ringing. Data Point 3: static failure test Using a test set up and a torque wrench, I was able to determine that the join failed with a single loading of between 3X and 5X CIM_stall_torque. This is better than predicted but not that encouraging considering that the "failure" was basically a spungy type event, allowing for actual failure to begin at lower than 3X. See picture. Data Point 4: Cycling Failure test Using the same test set up, I was able to show that the joint will fail at 2X CIM_stall_torque with repeated loading. See Picture. Data Point 5: Failure in the field This still did not mean that teams would see failures in the field because we don't know the dyanmic loading that we expect to actually see during real world conditions. I typically use 2x as the dynamic load factor, but that is not a law of physics it is just a rule of thumb. So... ...we needed confirmation. Team 166 uploaded a picture that confirmed this problem will be seen by teams. This is after 3 hours of driving. Team 166 did not say what ratio & how many CIMs they used, but I suspect it was 16:1 with 1 CIM. Will someone from 166 confirm this please. Where do we go from here? Now, what do we have to do going forward? I believe that we can get a quick 2X in the output by simply getting harder carrier plates (RC 23 or higher). I believe that will almost certainly get us to the 12:1 1-CIM case as well as the 16:1 1-CIM case. What it does to the 2 CIM cases, I can't predict. My best educated guess is that for most teams the this will address the problem for the 2-CIM cases too, but I have to be honest, the picture from 166 has me worried. If they were in fact using the 16:1 1-CIM set up, then going to a 2X hardness will be exactly matched by a 2X in loading due to the 2-CIMs. We need more testing and we need more thought on solutions. More Information For your information, Banebots is well aware of this. They are working hard with FIRST, their suppliers, and yours truly to get a good solution out there to teams. Everyone is sorry. Beating us all up will not help. Calling them will only take time away from fixing the problem. We are working on it. Joe J. Last edited by Joe Johnson : 29-01-2007 at 13:30. |
Re: Banebot 56mm gearbox - double D related
In the pictures of the failed plates, it looks like the shaft is not fully engaged with the plate. In addition to hardening the plate, it might be worthwhile to look into some type of mod to the shaft to get full engagement.
May I add that this same problem is happening with the 42mm gearbox's, which many teams planed to use with the FP motor to power an arm. It will fail on you quicker than the 56mm drive gearbox's. If I was on or mentoring a team planing on using these gearbox's I would tell them to grab a pair of single speed Andymark gearbox's which for the same price accept 2 CIMs or 1 Bike CIM and 1 CIM.
I have been following the banebot transmission failure threads for some time now and now I feel teams need to take action.
We are currently running 2 CIMs on each gearbox...so we definately need to get parts made. At the moment are transmissions are on the robot and not easily accessable, but we will get to them to replace the Double D plate. We have yet to have an issue...but are going to take precautions now. Does anyone have a CAD drawing of the piece that needs to be made? It is my hope that teams which have the resources...get many of these plates made to help out other teams who are not as lucky. I would love to not have to worry about it and wait for BaneBots, but their response time (at least with me) was not acceptable. Teams need to start production now so the plates can be replaced BEFORE regionals. |
Is the double D shaft pressed into that plate, or it just sits in there? Howabout the planet pins? This part that fails is just a 2D geometry plate? Is it easy to swap out? We have a lasercutting sponsor. There is a chance we may be able to set up a large production run of lasercut plates available for a small cost. Is laser accurate enough (draft angle)? What kind of material would it take to make this plate never break? How would it have to be treated/hardened? Joe, talk to me.
I want this to be a good year for FIRST. A robot that drives without worry is the key to success.Last edited by sanddrag : 29-01-2007 at 16:09. |
Is this a problem only with a 2 motor setup? Should we be concerned if we are just using one CIM per gearbox?
The good news is that when it fails it doesn't seem to take the rest of the gearbox down with it. It is not ideal but it is something. Joe J. |
Dr. Joe...
When we reported the gross failure of one of the drive systems, we failed to mention that we pulled the other three gearboxes off and observed the same damage, although to a lesser degree. Ron Reich, a new ME mentor on the team, had done the research and determined that the 4140 prehardened steel would provide double the resistance to stress that the original carrier plates can withstand. We will be having new plates made and as soon as we get them, we'll report back on how well that works. C. B. Petrovic - Team 166 |
Instead of a shaft modification, perhaps a select fit washer to control end play might help. |
#10
we put a washer behind the gear that connects the 2 CIMs together. it did help a little bit but the 4:1 gears were constantly grinding against the dual CIM adapter where the screws hold the 2 together. and adding enough washers to keep from grinding would have pushed the gear to far forward it wouldnt be connected to the CIM gears, or the would barely be connected and cause just as many problems.
#11
Yes, you are right. When we first assembled the motors onto the gearboxes, we needed shims to get the spacing right. This was done in accordance with the message from Banebots. After making hasty repairs to the failed plate, we discovered that the .040 shim was not necessary, nor were any mods made to the spacer, pinion or CIM shaft. After pulling the remaining 3 gearboxes apart, all of which had the .040 spacers, we found these to have similar wear/failure patterns. Reassembly no longer required the shims. We should have used our heads and run them no-load for a period of time for break-in purposes. Oh, well, add this one to the "lessons learned" list! C. B. Petrovic |
#12
Dr. Joe.
We are using 1 CIM w/ 12:1 ratio. An ME here would like to know how you calculated the stress. Below is his observation from the photos as well as conversations with me. "The initial interface is 2 lines of contact (essentially zero area) between the shaft and the D hole. It is only after material begins to deform (ever so slightly) that area contact is made. I am curious what he uses for stress area and how he determines it." C. B. Petrovic Last edited by cbpetrovic : 29-01-2007 at 15:48. Reason: Additional material |
#13
I hope that helps. Joe J. |
#14
Re: Banebot 56mm gearbox - homebrew hardening?
Would a homebrew hardening of the plate be of use in helping this problem? Heating it to red-hot and tossing it into a bucket of cold water seems like a fun experiment. Into potentially explosive oil could be even more exciting (just kidding, this could/would be very dangerous). http://www.efunda.com/processes/heat...ing/direct.cfm
#15
Is there any possibility FIRST would let us use last year's transmissions as a solution?
This is so bad I can't even understand how this mistake could happen. We have been planning for a year and getting ready for this year’s competition and we may be sunk before we even take the field. Why were these things not tested before the switch was made? boooo ![]() |
| small banebot motor with 64:1 gearbox | burkey_turkey | Motors | 16 | 29-01-2007 01:48 |
| opening up the BaneBot gearbox to install the CIM motor | jskene | Motors | 9 | 22-01-2007 11:12 |
| Banebot Gearbox | chris31 | Technical Discussion | 45 | 15-01-2007 17:56 |
| Attempting to Cut BaneBot 56mm Shaft | edthegeek | Motors | 6 | 15-01-2007 08:51 |
| 56mm BaneBot Gearbox 15tooth sprockets. Where to buy more? | VEN | Technical Discussion | 4 | 11-01-2007 14:45 |
