Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 29-01-2007, 19:19
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Rendering procedure and questions
This will be my first year doing this so its a little new to me as far as rendering procedure. I have a series of questions and I could use some pointers too (as well as some other people I hope )
-Can I set up and render into one file, several different scenes. They all have different lighting in them, one even uses video post.
-Should I be using skylight (makes everything look better) and if so, how long for an animation usually would you guess it would take with a network render on ~18 computers? All with about 1 gig of ram (I dont know much about network rendering though)
-I have no clue what I am doing with network rendering, but I have found a tutorial on it, but if you have any pointers it would be very helpful (I saw someone here doing it well)
-The thing about the blank borders, is there an easy way to do this without having to edit all of my cameras?
-Is another program allowed to be used to join clips together, or make the border?
Thank you.
Visualisation entry procedure & forms thoughtful 3D Animation and Competition 0 16-02-2004 23:33
radiosity and rendering kcy88 3D Animation and Competition 13 15-02-2004 00:59
Standard Operating Procedure K. Skontrianos General Forum 7 01-03-2003 14:02
