Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 30-01-2007, 10:44
itay_ms itay_ms is offline
FRC #2215
itay_ms is an unknown quantity at this point
battery plug
with which material can i use to extend the plug of the battery with the wires ?
Unread 30-01-2007, 11:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: battery plug
Itay,
You can use a splice block with another section of #6. You can purchase additional Anderson Power Product terminals from terminal supply and make your own. I discourage either of these as it tends to make the wire runs too long. You want high current wires to be short. The supplied electrical distribution blocks are perfect for extending or distributing this wiring. The "Tips and Guidelines" on the First website under Robot Documents, has a good explanation of wiring.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 03-02-2007, 15:11
teddybear teddybear is offline
FRC #0234
teddybear is an unknown quantity at this point
Re: battery plug
I'm sorry, I stil don't know what a battery plug is. Good luck with that one.
Unread 03-02-2007, 21:32
Unsung FIRST Hero
Rookie Year: 1996
Re: battery plug
Teddy,
The battery plug are the red Anderson connectors with the red and black #6 wires attached. They are needed for wiring to the battery and for connecting the conncetor to the main breaker and negative side of the terminal block.
Al
WB9UVJ
www.wildstang.org
Black Battery Plug contest from AndyMark Andy Baker Kit & Additional Hardware 11 10-01-2006 21:37
NBD: A Shameless Plug... Joe Johnson General Forum 0 02-01-2005 14:55
Battery Charger for long term battery care DougHogg Kit & Additional Hardware 0 08-02-2003 15:25
Relay Output Plug archiver 1999 3 23-06-2002 21:56
A plug-ish question Ydnar 3D Animation and Competition 1 25-01-2002 01:22
