Go to Post you don't need a fancy workshop to build a good robot, just determined people. - pacoliketaco [more]
Unread 30-01-2007, 13:31
almsfan21 almsfan21 is offline
FRC #1804
almsfan21 is an unknown quantity at this point
Re-wiring 24V double solenoids
I am trying to figure out how to re-wire the 24V to 12V on the double solenoids. Our "inventory" person lost the instructions on how to. I know I am supposed to replace the coils, but do I just use the one from the single 12V solenoid??
Unread 30-01-2007, 14:33
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Re-wiring 24V double solenoids
Good morning,
If you are simply trying to fix the solenoids you recently received from SMC it is very simple...no wiring required...
On the side of each double solenoid and one side of the single you will find small grey coils which are marked 24 volts...
Remove the two screws that hold them in and use the replacement coils provided by SMC in place of them... You even get extra screws if you lose one while taking them out....
that's all you need to do... replace the 24 volt coils with the 12 volt coils and
bingo you have 12 volt solenoids...
I hope this is what you were looking for...
good luck!!!
R
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 30-01-2007, 14:35
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
In the shipment of the late KOP pneumatics you should have received a bag of loose grey 12v coils. The other bags with the double and single solenoids all came with 24v coils installed.
I'd mark all the coils before you start so you don't easily mixup the 12 & 24v parts. Then remove all the coils (24v) attached to the SMC solenoids and replace with the loose 12v coils.
- *QTY 2: Double solenoid valve, 24VDC (PN SY3240)
- *QTY 1: Single solenoid valve, 24VDC (PN SY3140)
- *QTY 5: 12VDC replacement coils (PN SY114-6LOZ)
* You must remove the 24V coils from the solenoid valves and replace them with the grey 12V coils before installing them on your robot. This is done by removing the mounting screws, and switching the 24V coils for the 12V coils provided. More information about these valves is provided in the FIRST 2007 Pneumatics Manual posted on the FIRST website:
http://www2.usfirst.org/2007comp/other/2007%20FRC%20Pneumatics%20Manual.pdf
have a question to ask about Double Solenoids to one spike programming davelu Programming 3 22-02-2005 09:52
Purchasing double solenoids bob1million Pneumatics 11 08-07-2004 03:17
wiring solenoids Brawler006 Electrical 10 22-02-2004 21:06
Double Solenoids - assembly. Frank(Aflak) Pneumatics 9 06-02-2003 20:33
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
