Go to Post "Pimp my shopping cart"?!?! - dlavery [more]
Unread 30-01-2007, 15:38
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
Beginning of Match - Charged tank
Presumably before the match starts, the robots and their compressors will be disabled. How then can we use the suction cup to hold the Keeper. Do we charge up the tanks and run the vacuum pump somehow off of them? In that case we might run out of suction if before the match begins. Hmmm, any thoughts?
Unread 30-01-2007, 15:50
Hieb Hieb is offline
Team Role: Teacher
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
Re: Beginning of Match - Charged tank
You won't be able to use the suction prior to the beginning of the match. You could position the keeper in such a way that once the match began it would then be engaged by the suction.
Unread 30-01-2007, 15:55
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
We have been thinking about the same thing and I disagree with your assesment. With a little creative plumbing you can store a vacuum prior to the beginning of a match. Lock it in with a solenoid then activate it manually to express the vacuum at the cup before the match begins. Once the robot is enabled, normal operation takes place.
Keep in mind also that there is no rule that prohibits beginning the match with fully charged pneumatic storage tanks. Just before your match run the compressor to fill everything up so you don't spend your entire auto period running the compressor.
Unread 30-01-2007, 16:10
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
This is all part of the design challenge of this years game. I dare say, it will take a little crative thinking to handle this particular situation. But as always happens, the solution will come in many forms.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 30-01-2007, 17:31
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Tuba,
The problem with venturi vacuum systems is you need airflow to the develop the vacuum. Without the robot running, keeping a charged tank while waiting for the match to start is going to be difficult.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-01-2007, 18:05
AKA: Dan
Originally Posted by Al Skierkiewicz View Post
Tuba,
Yes I agree, but once you have a vacuum you can engage the tube and lock it in. It is possible to do this manually during the field setup before the robot is enabled. We have tried it out and it works! If you establish a good seal with the tube, the vacuum will maintain for quite a long time. You just have to figure out a way to prevent atomspheric pressure from leaking back in at all possible openings HINT HINT!
Unread 30-01-2007, 21:20
Unsung FIRST Hero
Rookie Year: 1996
Wink and a nod....
Al
WB9UVJ
www.wildstang.org
Using pre-charged accumulators Peter Matteson Pneumatics 8 14-02-2006 10:42
beginning of a match Jess1513 Rules/Strategy 2 10-02-2005 22:05
Single Tetras at Beginning of match? Deltafrog Rules/Strategy 6 09-01-2005 12:48
Charged 7.2 battery Daniel Brim Electrical 2 01-02-2004 10:46
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
