Go to Post As a rookie team member at my first event, i had a great time, the little glitches meaning nothing. - Gluedtothefloor [more]
Unread 30-01-2007, 17:30
almsfan21 almsfan21 is offline
FRC #1804
almsfan21 is an unknown quantity at this point
Help with double solenoid
We attached our double solenoid to our cylinder and it was very slow on retraction and extension. We have the pressure coming in through the P hole on the three holed side, with the exits to the cylinder to through the A, B port. It was really slow. I checked the pressure after the solenoid and it was getting full pressure. Any ideas?
Unread 30-01-2007, 17:54
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Help with double solenoid
It sounds as if you might be applying equal pressure to the top and the bottom of the cylinder at the same time. Is the cylinder just moving out? Or does it move slowly in BOTH directions? I'm not looking at the solenoid right now, but make sure your supply pressure is 60 psi and connected to the P port. One side of the cylinder should be connected to port A and the other to port B. Finally make sure the exhaust ports (EA and EB) are both open. Finally do you have a needle valve installed? If you do you might need to open it a bit more.
Unread 30-01-2007, 19:57
FRC #1804
Thanks man, I figured it out...I had EA and EB blocked off..oops. But we figured it out, I appreciate the help.
Double Solenoid Help doyler Programming 4 19-02-2005 11:36
Double Solenoid Wiring blindguyinanorg Pneumatics 7 09-10-2004 23:55
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
Double Solenoid Leak Darksun Pneumatics 4 18-02-2004 22:52
double solenoid gail OCCRA 0 11-10-2002 19:42
