Go to Post I'm so conflicted right now. On one hand, you made the same page as a celebrity. On the other hand.... Justin Bieber. - Akash Rastogi [more]
Unread 30-01-2007, 18:08
Marc@tnt280.com Marc@tnt280.com is offline
FRC #0280
Marc@tnt280.com is an unknown quantity at this point
Unhappy CMUCam GUI
I am a programmer on the team TNT280, and I was wondering if any one is able to find the CMU cam 2 GUI. I have found a few GUI versions, however none are quite as well as the one I saw with the Thunder Chickens..However, they used some file called CMUCam 2 GUI.vi, I have not been able to find that file on the internet. Is there any way to find that file, or does anyone have it or instructions in which I can aquire the .VI file?
Unread 30-01-2007, 18:09
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: CMUCam GUI
Check out this thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=41214
Unread 31-01-2007, 15:13
FRC #0280
Angry Re: CMUCam GUI
The problem with all the files that I managed to find within that link is that the files seem not to be compatible, or very, with Labview (version 8.2, I believe). The problem is mostly that it does not find the other files associated with the CMUCam2 GUI. When I try to run the program it tells me that it does not have all files required (There is a ftp website given there, that I was unable to try), in addition to that there is a error that tells me that it is not interfacing with the camera.
Unread 31-01-2007, 18:29
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Re: CMUCam GUI
Here's a link to the Java GUI.
http://www.cs.cmu.edu/~cmucam2/downloads.html
Labview GUI Booger NI LabVIEW 3 11-08-2006 11:05
CMUcam2 GUI Program nukem Programming 4 15-01-2006 03:19
GUI Program error muy dificil Programming 0 27-10-2005 11:10
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
Auto GUI VanWEric Programming 1 12-02-2003 01:46
